| Rock Crawlers For those Rock crawling, stone sliding, body scratching, articulation crackheads; this place is for you! |
#31
awsome truck I have to learn how to make one of those bodies there sweet. |
Your tubing looks thicker than brakeline. Have a link to where you got it from or specs "wall thickness" Looks clean I'm waiting on some solid rod to show up and I'l be making mine here shortly
#33
love the beaten look! looks so real.. and that shows that ur rollcage structure holds very well! bet people survive in that cage even in 1:1.. you got terrific talents there, man.. congrats!
#34
![]() Quote:
The coolest thing is that I can change the body at will and it don't cost me a dime! I've got stacks of aluminum cooking sheets ![]() Quote:
![]() Thanks! yep the cage is super strong. it's taken some real nasty tumbles and the only thing I tweaked so far was the stinger but only the top where it's unsupported. |
#35
All right guys here is the quicky version on how I did the molds.
first I take the body that i want to copy and I add cardboard to surround the section I want to duplicate ![]() ![]() ![]() Then I fill it with plaster and when I pull it apart I have a negative ![]() Then I add more cardboard around the sides and then fill the whole thing with bondo. Yep like you use on cars ![]() ![]() Then I pull it apart to reveal an exact duplicate of the original body and in this case I cut it into sections ![]() Here is the rear fender as it came out of the mold ![]() For this truck I wanted a bobbed bed so I made another set of rear fenders and cut about 3/4" out of the back ![]() ![]() then I bondoed the pieces back together ![]() and sanded it down ![]() I did the same for the tailgate ![]() the full size gate started like this out of the plaster mold ![]() this was the first mold I made so I had to test it with the aluminum ![]() then I cut it into it's respective sections ![]() and made another test panel ![]() I'm terrible at documenting my work in progress. I like to just get it done so this really isn't' the complete process but just the basic concept. I'm going to do a proper write-up when I do my next body, an F250 Hi-lift! ![]() |
#36
Well I haven't done much to this lately but After the last comp I decided to pull the panels and streghten them for the next comp so I figured I Would give everyone a little idea of what it takes to put the body on this truck
To start I first remove the cowl with 2 screws ![]() ![]() ![]() then I raise the hood and take out the 3 screws holding the top of the fenders on ![]() then 1 screw at the bottom ![]() and the fenders off ![]() Next comes the doors. A screw under the fender and in the B piller secure it into place ![]() and it simply slides out of the boat sides ![]() Looks kind of neat without the doors and fenders huh? ![]() Then the roof simply slides off ![]() Not much to it! ![]() The body got beat up pretty bad this last comp but it's still holding it's shape. I hope it will make it through the next 2 comps and I'll make more panels for next season. I want to concentrate on my scaler now. |
#37
Awesoe Job!
Are you using pie tins for the panels or something else like flashing?
Yes it is pie pan tins. I use flashing for heavier stiff like floor supports and bed mounts.
#39
I'm amazed!
will deffinately have to try this technicque. thanks for sharing neil
Cool Cant wait to give it a shot!
Really Great !!!
#42
I am going to have to get some Bondo, plaster and pie plates.
That is one of the coolest bodies I have ever seen.
Spending money I don't have, To buy parts I don't need, To impress people I don't know. |
#43
#44
I love it and have built almost the same thing as a 1:1. Everything flows together and looks mean.
#45
were you at the harrisburg motorama? if so the pics of your rig my friend took are badas#.
| Thread Tools | |
| Display Modes | |
