Old 01-09-2009, 06:38 PM
crashaholic's Avatar
crashaholic crashaholic is offline
Will crash cars for food!
Member Number: 1217
Default Leo's Willy! **SHE'S DONE!!!**
Well I must have done something right with Aaron's Yota build because I had another sucker... uh i mean customer ask me to build them a truck and with the holiday's behind us I finally had some time to start it.
This one will be a Willy's similar to the green one i made but with some changes that Leo (Ljk) wanted. This will be leafed with AX10 axles and a lot more scale details, a full exo and tube front fenders, roof rack, tire carrier Etc.
Anyways here is some progress.
I decided to try some aluminum foil from Dick Blick someone showed me. http://www.dickblick.com/zz605/03/ Since I wasn't going to be in for a couple days I started on the chassis. I began with an exact drawing of an original willy's frame I found on the net and scaled it up to fit the body, then shaped the 1/2" square tubing to match
I sliced it down the middle and wire brushed it clean
then I made the front and rear bumpers
The metal showed up sooner than I thought so I started on the body
This metal seems to be the same thickness but is much softer and easier to form.
I was able to get some detail I couldn't before.
Here is a close-up of the grill. It came out better than my previous ones
Once I complete the cab I'll get the chassis set-up and start on the cage. This should be a fun weekend!
Old 01-09-2009, 06:41 PM
Stormin2u's Avatar
Stormin2u Stormin2u is offline
Incredible Taylors Falls
Member Number: 2386
Now that is interesting how cool.
Old 01-09-2009, 07:53 PM
igotit's Avatar
igotit igotit is online now
So many posts I can slap yo mama!
Member Number: 3180
sweet build bro!
how tough is the aluminium,after its shaped ?
or is that plastic parts with the foil shaped over it?
if ya dont mind sharing!
I hope this guy gets hit by a Toyota with a stuck accelerator or faulty brake system.
hmmm ....i own a 07 toyota fj.....i wonder if it was on that big recall list
Old 01-09-2009, 07:57 PM
4RUNN1's Avatar
4RUNN1 4RUNN1 is offline
Member Number: 3400
Crazy metal work watching this for sure ...
Old 01-09-2009, 08:16 PM
warnoffroad's Avatar
warnoffroad warnoffroad is offline
TUG-O-WAR Lord.
Member Number: 403
Here comes the drool!
Im actually a 75%er that's just giving you an extra 20%
Old 01-09-2009, 08:31 PM
caymin last's Avatar
Member Number: 3754
Watching this closely!
Old 01-09-2009, 10:41 PM
Bigbadwhitey666 Bigbadwhitey666 is offline
Member Number: 48
Just Awesome! Cant wait To see More.
Old 01-10-2009, 03:06 AM
roverv8 roverv8 is offline
Member Number: 6118
amazing metal body, it really looks like a true one !!
Keep up the good work
Old 01-10-2009, 03:23 AM
cambodian tire's Avatar
cambodian tire cambodian tire is offline
Member Number: 378
Wow! where did you learn how to do that?! I used to do models and now some scale stuff but that's incredible! Is there some secret group of people that fab only in metal/tin supported by magazines and web sites that I've never been exposed to? I'll definitely be watching Keep up the great work!...Mark
Old 01-10-2009, 10:02 AM
SpZero's Avatar
SpZero SpZero is offline
need stronger parts that dont break
Member Number: 4132
sweet these alloy foil skinned builds are always amazing!!!
thought thats how you deep cleaned the brown eye?.
my r/c's
Old 01-10-2009, 11:28 AM
chevy55's Avatar
chevy55 chevy55 is offline
Member Number: 4174
awsome skills
Old 01-10-2009, 11:52 AM
cherokee95's Avatar
cherokee95 cherokee95 is offline
I'll keep my money, my guns and my freeedom.....you can keep the "change".
Member Number: 1617
Dang, your builds just keep getting better
President
King Cobra 1972-2009/Warnoffroad 1987-2010
Old 01-10-2009, 06:16 PM
TrueThorne's Avatar
TrueThorne TrueThorne is offline
GodSpeed
Member Number: 5145
thats awesome work!
Build-Bash-Rebuild
Old 01-10-2009, 10:50 PM
Member Number: 1217
Thanks everyone for the kind words!
sweet build bro!
Once it's shaped it's pretty strong. The Toy panels are much stronger because of the curves but both bodies seem to hold up well to general abuse.
I started by using household aluminum foil on matchbox cars about 25 years ago and have slowly progressed into what you see here. No one taught me this (considering I believe i'm the one that pioneered it anyways ) It was something that I just kept experimenting with and evolving over the years.
I do use some techniques from real life body fabrication but there is no secret underground metal RC car fab group that i know of. Hmmm... maybe I should start one!
Well after getting through my honey-do list, I got some more work done on the body.
Started the floor pan using some paper templates I had made up when I first built the flatty
I traced out the pattern on the new metal. Man I love this stuff!8)
then I cut it out
and broke the edges using my "sheet metal brake"
then I moved onto the inner fenders using the same technique
to get the corners I placed the part on the body and worked the metal around the edge
then I made the front floor pan
and glued the pieces together
It's coming along pretty good and I should have the basic cab done tomorrow.
Time to hit the sack
Old 01-11-2009, 07:44 AM
nataliemorgan's Avatar
nataliemorgan nataliemorgan is offline
VDub Luftwaffe Pilot
Member Number: 2469
Nice Job! Very nicely done.. Cant wait for more.
Hosted by Global Gold
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2004 - 2010, Scale 4x4 R/C
