Old 02-27-2009, 02:09 PM
crawlingman9000's Avatar
crawlingman9000 crawlingman9000 is offline
eat, sleep, jeeps
Member Number: 7022
dude that is sick!
i love the scale elipticale in the rear. this setup works really nice.
Old 03-02-2009, 08:31 PM
topolino's Avatar
topolino topolino is offline
doido por 250!
Member Number: 2322
Amaaazing job!!
bada*s!!
Old 03-21-2009, 09:25 PM
crashaholic's Avatar
crashaholic crashaholic is offline
Will crash cars for food!
Member Number: 1217
Thanks everyone! Yes the whole chassis is TIG'd.
Sorry I haven't be updating this. the family has ween sick the past couple weeks and that severely hinders progress but I finally got the motivation to get back onto this. My wife actually had to kick my but to get working on it.
Anyways I got a good bit done the last couple days.
First off I finished welding the lower control arm cross member and tacked it into place
then I started on the cage
The cage will have cues from Poison spider customs cages so i started with the front hoop
I had to dog leg the down bar just a bit to get the right position on the foot
Then I bent up the halo
Then tacked it into place
Next came the bars behind the seats. These were a bit challenging. I wanted to mimic the angle of the front hoop and that came out pretty well
but the tough part was getting the bar up past the inner fenders
they also taper in as the meet the halo which make for a tricky compound bend but it worked out ok
next was the rear bars. I wanted to mount them in the tub so everything would remain removable so i whipped up some plates. One is tapped the other slips the screws through
then I secured them to the tub sandwiching the body between them
then I ran the bars from the halo to the mounting plates
then to support it I ran tubes from the chassis to the lower plate
then the last thing to go on was a few bars to finish the top
Now I'm beat! I hope to get the rest of the cage tacked up tomorrow as well as the rear tire carrier.
Night!
Old 03-22-2009, 12:03 AM
Ryan_m Ryan_m is offline
Member Number: 5948
I wish I had 1/10 your skills.
Keep up the good work and thanks for posting
Old 03-22-2009, 12:15 AM
pantablo's Avatar
pantablo pantablo is offline
Mr. Tire Guy
Member Number: 3012
beautiful.
Pablo
Old 03-22-2009, 02:16 AM
lemecanodejante's Avatar
lemecanodejante lemecanodejante is online now
Member Number: 1144
exactly what i think
Old 03-23-2009, 04:26 AM
Member Number: 1217
Thanks again guys
Got the rear tire carrier done last night keeping with the Poison Spider Customs theme.
Started with some mounts similar to the ones I made for the axle
then I tacked them to the bumper and added some small tubing inside them
next I bent up the stinger and tacked it into place
now for the tire mount i bent up some small sections and tacked them to an old axle shaft with a washer
starting to look like something now
Here is is folded down
and how the tire is secured
Now the top mount. I made up some more tabs
then tacked them to the tub hoop
and finally added some more bars
Turned out real nice and works good
Here is a shot of the whole chassis so far
and with the body on
Enjoy!
Old 03-23-2009, 07:12 AM
Spoon37's Avatar
Spoon37 Spoon37 is offline
Member Number: 16
sweet
great work on the tyre carrier
Mmmm Bunnies...
Old 03-23-2009, 08:29 AM
slither302's Avatar
slither302 slither302 is offline
Member Number: 2185
This has got to be one of the best builds.....period! Do I hear TOP BUILDS
Old 03-23-2009, 01:18 PM
stevieb337 stevieb337 is offline
slowly losing my marbles
Member Number: 7124
WOW nice fab skills
Old 04-01-2009, 09:17 PM
Member Number: 1217
Thanks again for the kind words! it really keeps me motivated to keep rolling.
I don't know about that. I guess we'll see once it's done.
Well I have a little update.
I looked at the front of the jeep for a long time and finally did it
Yep, I just couldn't stand the grill hoop any more. It was bugging me being smaller tubing so i wacked it off.
Up until now i was having problems bending the 1/4" tubing real tight but now that i found my brake line bender i could fab up the right hoop
I like it much better now
While I was at it I also trimmed the front frame down
and added the bumper.
The stinger will go on later
The last 2 days I spent time finish welding the cage and frame then i re-attached the suspension to work on the shock mounts
This time in the front I secured the axle a bit more firmly then the duct tape i had before
It's just threaded rod bent into a U then through a plate. It's temporary until i get the right solid rod. that will get bent then tapped at each end for a more realistic look.
eventually It will also have centering pins in the springs once i get the final spring packs made up and the axle centered properly.
then I mocked her up to get a good look at her as she sits now.
This is pretty much how it will ride when it's completely done. I'll need to play with springs once i get everything loaded onto it. this thing is going to be one heavy pig! it's already heavier than Joe's jeep and this has no running gear electronics or accessories!
more to come as i get the time
Old 04-03-2009, 06:23 PM
d.k.v's Avatar
d.k.v d.k.v is offline
King Of Weird Ideas
Member Number: 3739
now thats the best welding iv ever seen on something so small
Old 04-04-2009, 04:48 AM
BillH's Avatar
BillH BillH is offline
Member Number: 1368
WOW enough said
Old 04-04-2009, 08:42 AM
Member Number: 1217
Well it's ok. Not as good as i would like it to be but i am getting better
Here is some of my more recent welds
Like I said they could be better. Right now i'm using 3/32" tungsten and .030" MIG wire for filler rod. I'm going to try to switch to 1/16" tungsten and .025" MIG wire to see if I can get the welds even smaller.
Old 04-04-2009, 08:46 AM
d.k.v's Avatar
King Of Weird Ideas
Member Number: 3739
any updates?
Hosted by Global Gold
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2004 - 2010, Scale 4x4 R/C
