Old 09-30-2009, 03:20 PM
SwampRatt-1977's Avatar
SwampRatt-1977 SwampRatt-1977 is offline
Go'in where the cattails are gro'in
Member Number: 7267
Default motor question
i have a high lift trans and a 10lbs truck and tamiya lunch box ESC and i need a high rpm, high torque motor. what do you guys think i should run
Old 09-30-2009, 04:26 PM
benoj's Avatar
benoj benoj is offline
Chevy crawler
Member Number: 5797
with a 10 lb rig and that speedo u are limited, with high rpm u lose torque so u get one or the other i would try a hh 35-45t. and how big is this rig to weigh 10 lbs my super weighs that much!
Old 09-30-2009, 06:21 PM
2011 Post Whoring Champion
I think you should run to the LHS and pick up a better speedo.
Old 10-26-2009, 06:34 AM
Siggy's Avatar
Siggy Siggy is offline
Let's Go!
Member Number: 4423
I'd go with the suggestion to upgrade the ESC and drop in a decent motor.
I have a HH handwound 45T on my Tundra + MFC-02 ESC. Torque is ok BUT the stock motor runs even faster. 45T might be ok with a nice ESC or a 35T, if possible a 7T Cobalt Puller, for sure.
