Old 08-17-2010, 07:43 PM
brazwewn's Avatar
brazwewn brazwewn is offline
1% Inspiration - 99% Perspiration
Member Number: 11667
Default IFS LR3 "Rock Racer"
I have begun collecting parts for my winter build. I started off down the road of making a Baja Bug Rock Racer. I just couldn't get enthused about the body, so I hunted around the net until I found the LR3. I was hoping for a lighter body, but whatever. I am going to build a front interior, but the back will just be flat cargo area. Maybe where the spare is stored??
My plan is to use a solid axle rear and a highly modified Slash front end. That is where the IFS part comes into play. My goal is to have a Summit 2 speed trans and maybe a transfer case. It would be nice to have the trans up front. Not sure how the space will be with the IFS though. I am also planning on making my own chassis and definitely an exo-cage
This will take some time, but when I get parts I will update.
Wes
Added some updated pics of the rig as she sits now, still need a name!
Last edited by brazwewn : 10-10-2010 at 07:00 PM. Reason: Added some updated pics!
Old 08-17-2010, 07:52 PM
pardonmyn00b's Avatar
I ain't not a dorkus
Member Number: 8206
Looks good just how it is
Old 08-17-2010, 08:00 PM
russisloud's Avatar
russisloud russisloud is offline
king russ of da' loud
Member Number: 3265
B/S/T Feedback: (19)
nice truck
Old 08-17-2010, 08:05 PM
Waterboy's Avatar
Waterboy Waterboy is offline
Member Number: 10658
B/S/T Feedback: (9)
The slash is wiiiideeee. For what your going for id just mount it on a cc01, has a solid rear axle and ifs.
W@T3R8oY wUz H3R3! Well, im Broke MoFo #89!! Eat that Lauer!!
Im suffering from RC addiction. Oh it hurts so good.
Old 08-17-2010, 08:07 PM
russisloud's Avatar
Member Number: 3265
but thats kind of the easy way out......looking forward to seeing this set up
Old 08-17-2010, 10:42 PM
brazwewn's Avatar
Yeah, I especially love the gi-normous front bumper!
Wes
Old 08-17-2010, 10:46 PM
brazwewn's Avatar
I am going to shorten the upper links and use a rear lower link. I still need to work out exactly which one, but it should narrow it in a bit. The CC01 is a god idea, but I am looking for a bit beefier suspension.
Wes
Old 08-17-2010, 10:47 PM
brazwewn's Avatar
Amen, the build and all it's headaches are half the fun.
Wes
Old 08-17-2010, 10:51 PM
brazwewn's Avatar
Here is my shopping list so far.
Wes
Traxxas Summit Tranny
MIP #08137 Drive Hub, 6mm (2)
1.9 Rok Lox (4)
Slash 4x4
RPM Rear Nitro Stampede Arms (2)or
Traxxas Bandit Arms (2)
Traxxas grey wide hexes optional (2)
MIP #08101 C-Drive Spline (2)
Proline Power Stroke shocks front (2)
Axial Rear Axle
Integy V11 35T
Transfer Case
Castle Creations Sidewinder - BOUGHT
Castle 10A BEC
3Racing winch
LR3 Body - BOUGHT
SCX10 Chassis
R603FF Receiver - BOUGHT
CS-150 Servo
Recarro Seat (2)
Old 08-18-2010, 06:15 AM
hawgfanman's Avatar
hawgfanman hawgfanman is offline
Member Number: 11971
Old 08-19-2010, 06:31 PM
brazwewn's Avatar
I got my truck in today and it is pretty sweet looking. I can see a lot of potential, but there are a few hurdles to overcome first. I measured my SCX10 wheel width from outside to outside of the tires. It is right at 9" with the Rok Lox. I then measured the LR3 which is 7 1/2" fender to fender. So I have a goofy looking ride if the axles stay the stock width. After some searching and brainstorming I got my answer.
First I will set aside the spacer on both sides of the axle. Then I will cut the axle shaft and remove a section from the middle. A coupling will be fabbed with a tight tolerance. This will be soldered together to end up with a shortened shaft. The bearing will fit into the stock location the front axle uses. Sorry for anyone not familiar with Axial, you will have to wait for pics. I bought an axle tonight. The axle spacer will be cut down so the only thing left is the part that pinches the end of the axle together. I will need to come up with a way to prevent the bearing from sliding out, but that should not be too bad. The end result will give me a outside to outside tire width of 7 3/8". Just shy of my 7 1/2" fenders!
Hopefully some pics to come shortly,
Wes
Old 08-19-2010, 07:18 PM
hawgfanman's Avatar
Sounds cool. Can you tell me the width of the body at the rocker panels? Thanks!
Old 08-20-2010, 07:42 AM
brazwewn's Avatar
Just a tad under 7 1/2" not counting the chrome plastic sliders. The fenders only flare out a slight amount.
Wes
Old 08-20-2010, 07:45 AM
brazwewn's Avatar
I think I found my tires for this build.
Dick Cepek Mud Country
Product Specifications:
Outer Diameter: 3.97" (101mm)
Width: 1.54" (39mm)
Inner Diameter: 1.9" (48mm)
Advanced X3 Soft & Sticky Compound
Reinforced sidewall
Wes
Old 08-20-2010, 07:47 AM
theres no way you are gonna cram a slash front end under that body. its WAY too wide.
