| Big Rigs, Multi axle, & Tracked Vehicles The place for "Semi" talk!
Tamiya and Wedico Tractor trailers! Tamiya and other brand R/C Tanks and Tracked vehicles. And any vehicle with more than 2 axles; 6x6, 8x8, 10x10, etc! |
ok guys im going to show step by step on how i do it
this will a longline edition scania 30 inches long all wheel drive 3 speed 55 turn motor 2 inch sleeper cab extension a small platform going to be a huge truck ok lets start with cab where im pointing i cut along the seam ![]() ![]() next i cut along the top seam, 52mm / 2 inches up ![]() then i cut straight across ![]()
time to make the extension
im making a tad longer then at 1st desribed my extension is 57mm, i need also to make left and right side the same shape as the side vanes where im pointing is how i get me shape ![]() here the 2 side are cut.noticed the shape ![]() on the back of the cab i needed to add 2x backers using 2x peices of 060 plastic card ![]() here i show the double backer on the back and i show the sideses on the cab ![]() now put the cab back together the same way you took it apart ![]()
time for the bonnet
you cut straight across the mounting holes for the aero cap ![]() ok under neath i just placed some backers.2x going diagnal to keep the cab squared ![]() on the bonnet, the outer part i used 080 plastic card, sand alittle now before it becomes to much on the corners i used 080plastic card , cut some lines evry 2.5 mm, then i curved them by popping each rib on top i used anoth 080.you can see where i stopped on the egde. ![]()
yesterday i primed it and today i sanded it.tomorrow i will prime again and start painting it italian red
frames are cut and ready for building ![]() ![]()
wait, can you go over steps 3 - 7 another time? and your doing it all wrong!
#7
are you done yet, its been almost 24 hours
#9
good one joe, i guess i'll dance too
#15
hey the paint looks good
| Thread Tools | |
| Display Modes | |
