Old 01-19-2011, 10:56 PM
mrgrandnational's Avatar
mrgrandnational mrgrandnational is offline
TRP operator FTW
Member Number: 4502
Default All Axle Dimension / Width / Gear Ratios
I'm rolling with the ball created by
http://www.scale4x4rc.org/forums/showthread.php?t=58163
I intend to put all the axle info I can find here.
METRIC STANDARD PRICE
I'm putting all the info first. The order can be rearranged later. I can also go to the trouble of resizing images. Any suggestions, more accurate info, please PM me.
1/18 Scale T-Rex Micro Axle
Width: 82mm/3.2inch FRONT AND REAR
Gear Ratio: 2.53:1
$49.99
ARB Special Edition T-Rex 60 Front & Rear Plastic Complete Axle
* Width: 190mm/8inch (Hex to hex) *PER RD4WD WEBSITE. 190MM ACTUALLY CONVERTS TO 7.48 INCHES
• Gear Ratio: 2.5:1
$109.99 FRONT AND REAR
Beowulf Rear Straight Axle for Tamiya Pajero/XC/Jeep
167mm per the picture. 6.57 INCHES
$99
Black Widow Crawler Axle
# Gear Ratio: 3:1
# Hex to hex width: 185mm 7.28 INCHES
# Fit 1.9 or 2.2 wheels (12mm Hex)
$149.99 FRONT OR REAR
Blackwell X1 Scale Axle
# Width 192mm / 7.55 inch- Standard overall width hex to hex (203mm) 7.99 INCHES
# Gear Ratio: 2.85:1
$179.99
Bruiser G2 Scale Axle
Hex to Hex width: 191mm/7.51 FRONT Hex to Hex width: 223mm/8.77 REAR
GEAR RATIO ???
$99.99
Bully Comp 2.2 Front & Rear Axle
# Width: 193mm/7.60inch (Hex to Hex)
# Gear Ratio: 38.42:1
$139.99 FOR BOTH
LIGHTWEIGHT VERSIONS AVAILABLE FOR $119.99-129.99 EACH
Bully XLD Comp Axle with Knuckles
# Fit 14mm back hex wheels
# Width: 264mm/10.4inch (Hex to Hex)
$99.99
D35 Front Scale Black Axle
# Width: 178mm/7inch FRONT Width: 176mm/6.92inch REAR
# Gear Ratio: 2.66:1
$119.99 each
D40 Scale Hi-Lift Axle
Width: 186mm/7.32inch FRONT Width: 184mm/7.24inch REAR
119.99 EACH
K44 Ultimate Scale Axle
Width: 176mm (outside hex to outside hex with 6mm hex)
166mm pin to pin F&R
Gear Ratio: 3:1
Leaf Perch mounts: 79mm apart
$149.99 each
Renegade Axle with Locking Diff
# Width: 187mm/7.36inch (hex to hex)
# Gear Ratio: 2.5:1
$169.99 each
Super Bully Comp Axle with Knuckles
# Width: 290mm/11.4inch (Hex to Hex)
$99.99
Super Bully Light Weight Axle with 65:1 Gearbox
Gear Ratio: 65:1
60% lighter in weight compare to the Alloy version.
$149.99
T-Rex 44 Mini Axle
# Width: 158mm (6-1/4in) hex to hex
# Gear Ratio: 2.53:1
CURRENTLY 99.99 EACH. NORMAL PRICE $139.99
* I JUST ORDERED A SET OF THESE. I'LL BE ABLE TO GET BETTER DIMENSIONS SOON.
T-Rex 60 Aluminum Axle
WIDTH 204MM / 8.03 INCHES
Gear Ratio: 2.53:1
5mm axle output shaft
$129.99 EACH
* ALSO AVAILABLE IN PLASTIC AT $79.99 FOR BOTH
The Ultimate Scale Yota 1.9 Axle
# Width: 180mm/7.09inch
$119.99 each
ALSO AVAILABLE IN HUGE 1/5 SCALE
# Fit 24mm back hex wheel
# Width: 380mm/15inch
8mm axle output shaft
$299.99 FOR THE REAR/ $349.99 FOR THE FRONT
Worminator 6x6 Narrow Axle
# Width: 159mm/6.25inch (Axle Housing)
# 12mm Hex
*Comp MOA Axle
# Gear Ratio: 30:1
# Width: 193mm/7.60inch (Axle Housing)
# 12mm Hex
$139.99 each
*Competition Axle
# Gear Ratio: 40:1
# 12mm Hex
$119.99
Narrow
MOA
Competition
TRP operator FTW
Member Number: 4502
saved 1
Per this thread: http://www.scale4x4rc.org/forums/sho...ht=axle+widths
Thanks to sloppy
Losi MRC 140mm/ 5.51 INCHES
Tamiya TLT 180mm 7.09 INCHES
Tamiya High-Lift 186mm 7.32 INCHES
Axial SCX 192mm 7.56 INCHES
Tamiya Jugg/TXT 260mm 10.2 INCHES
Thanks to hairba11
LT-1 is reported 6.6" from bearing to bearing 168MM
Highlift hilift is 6.875" bearing to bearing 175MM
wheelyking WK, Wheely King are around 8.125" bearing to bearing 206MM
Axial, AX-10, AX10, Scorpian are reported to be 7.0625" bearing to bearing 197MM
cc-01 xc-01 is 6.0625" bearing to bearing (rear axle) 154MM
TXT-1 is measured at 9.375" bearing to bearing 238MM
Clod clodbuster is also 9.375" bearing to bearing 238MM
Old 01-19-2011, 10:57 PM
TRP operator FTW
Member Number: 4502
saved 2
TRP operator FTW
Member Number: 4502
saved 3
Old 01-19-2011, 10:58 PM
TRP operator FTW
Member Number: 4502
I'm bored at the moment. saved 4
TRP operator FTW
Member Number: 4502
saved 5
All of the information after this post, if accurate, will be added to the original 6 posts.
Please don't give false info. Future builds may rely on this thread.
This is going to be a long process. Please check back in a few days.
Old 01-21-2011, 10:00 AM
nassosff-3's Avatar
nassosff-3 nassosff-3 is offline
Member Number: 14093
Saved...thank you
Old 01-21-2011, 12:12 PM
BiGDaWgZ's Avatar
BiGDaWgZ BiGDaWgZ is offline
~ Got PROPANE ? ~
Member Number: 7431
B/S/T Feedback: (92)
I think it would be nice to add Metric and Standard measurements (inches)...so that we can tell at just a glance.
Alot of them give both measurements...but some do not
Also...there were 2 different width's of D35 axles....the first versions...and the newer ones.
I believe the first versions were the same as the D40's...but the newer ones are narrower.
I will post pics and measurements of the Beefy Bruiser Replica Axles that RC4WD used to make/sell...they've been discontinued for awhile though.
I've got a new set of them coming to me in the mail (maybe today even ! )
Thanks for compiling all of this in one place.
ArOn
Old 01-21-2011, 12:38 PM
LondonF350's Avatar
London Scale Trail Runner
Member Number: 2745
Nice thread.
http://www.scale4x4rc.org/forums/image.php?type=sigpic&userid=2745&dateline=1248715  005
Old 01-21-2011, 03:10 PM
The_Stuff's Avatar
The_Stuff The_Stuff is offline
Thinking Big
Member Number: 1490
what would you use for the suspension on the 1/18 T-Rex
RC's are like pringles!! YouTube - http://www.youtube.com/user/thestuffz
Facebook - www.facebook.com/Thestuffz Blip TV - http://thestuffz.blip.tv/
Old 01-21-2011, 05:19 PM
TRP operator FTW
Member Number: 4502
This is slow going for now. I'm busy with a few other things. Like I said, anything posted after my primary posts will get added to the originals. I'll, more than likely, save your pictures and host them myself. I have a few "how to" threads on various forums; they've been up for years. I want to make sure that the pictures stay up. I hate going through old threads and reading all the cool comments on specific work. It piques my interest so I look for pics but can't find any photo of what they were talking about.
I'd prefer not to necro-post just to find out.
Old 01-21-2011, 05:32 PM
TRP operator FTW
Member Number: 4502
I added some color to the metric and standard measurements. I think the orange is a little hard to read. I'll probably change it to something that pops a bit more. THE COLORS HAVE NOTHING TO DO WITH WHAT I THINK ABOUT THE ITEMS OR MEASUREMENTS.
If I use PINK, it doesn't mean that I think it's (use your imagination). It's simply another color to use.
Old 01-21-2011, 05:54 PM
TRP operator FTW
Member Number: 4502
That's what I had in mind. I just wanted to have all of the information first. But I guess it should be useful with the info it already has. I added color for an even quicker reference.
I can also convert all of the standard measurements to what you'd see on a ruler/tape measure. If there are requests for it, I'll do it. Not everyone can do contractors math in their head. lol
Old 01-21-2011, 06:00 PM
TRP operator FTW
Member Number: 4502
I may not have noticed the measurements. If anyone knows, absolutely, what the input shaft measurements are, please post up.
Old 01-21-2011, 07:13 PM
TRP operator FTW
Member Number: 4502
I'll also get around to sorting this list by SIZE.
Doing what I can, when I can, while I can...
