| Big Rigs, Multi axle, & Tracked Vehicles The place for "Semi" talk!
Tamiya and Wedico Tractor trailers! Tamiya and other brand R/C Tanks and Tracked vehicles. And any vehicle with more than 2 axles; 6x6, 8x8, 10x10, etc! |
Hey!
I have been working on this project for quite a while now and been posting on a a local forum, but then i figured i post here and show you folks! the 1:1 machine. ![]() i have been building for almost a year and a half now with some breaks because of seasonwork. enough talking, now let the pics speak. Making some traxs ![]() ![]() Start of the chassi ![]() ![]() ![]() Made some wheels ![]() Chassi + wheels ![]() Chassi + Wheels + tracks ![]() Chassi + Wheels + Tracks + Kyosho Blizzard ![]() i just had to make a comparison between the 1:8 and the Kyosho blizzard.. seem a bit smaller.. Right now im working on the front blade and the motor that will raise and lower it.. looks promising. i have some more pictures and some videos, but thats for later! Cheers Joakim Last edited by Hajen : 05-25-2012 at 01:07 PM. |
Looking Good! I'm getting ready to start a very similar project myself. Not to out-do you or anything but I was thinking 1:6 scale. I've been drawing it up in Autodesk Inventor in my spare time (not a lot lately) and I'd like to start building after I get back from vacation in July.
Just a couple questions, What size materials are you using for your tracks? They look great! And, any ideas on the drive sprocket? Do you plan on custom machining it? ![]() |
#4
Nice to see others with similar projects! I use 10x10x2mm, not exatly scale but looks good in my opinion! I have done some drivespockets, handmade. Did about 3 versions before i found the best solution! I can post some pics when i get back from work!
Yea, it Will be kinda big! It weighs around 11kg right now! |
#5
I thought I was crazy making my tow truck,this thing is knutz!
Good work though keep it up. Greg
Large and in Charge! HD TOW TRUCK R.I.P. Freddy Geardrive. |
#6
@LOSIASSOCIATED - Thank you! i will try!
@Tyme2par4 ![]() right now its mounted on the machine, don't have any pic of it "loose" and its a pain to remove.. can take a better w/o tracks later. are you going for a dual motor setup or? what about the electronics? Started on the blademount! ![]() This is how it stands right now! ![]() ![]() and some youtube videos, first ever drivetest. Now -> to the garage. /J,.- |
#9
I definitely plan on going dual motor. As for what motors, not really sure yet. I haven't really looked into electronics yet. I have an airsoft tank that I may sacrifice for parts to start. I've been out of the R/C seen for a few years now so I'm a bit out of the loop with a lot of the parts. I'll have to start doing some research once I start building.
#10
I am using 2x lynxmotion motors and Sabertooth esc on my PB600.
It allows you to turn the PB or Tanks in a radius. http://www.lynxmotion.com/c-71-planetary-motors.aspx http://www.dimensionengineering.com/Sabertooth2X12.htm |
#11
This is amazing! Truly inspirational. I thought I was good with my dual motor Kyosho Blizzard DX! I am also running the dimension engineering Sabertooth 2x12, and I cannot express how much I love it. It has made the dual motor setup amazingly smooth... I use a pistol type controller to drive it.
#12
Looks like I may be getting myself a Sabertooth 2x12 from the reviews here!
Hajen, what are you using for a radio? How many channels do you plan on having? Im thinking 1 for each track (2), blade up/down, side to side, maybe tilt, then eventually the groomer up and down and on and off. Probably some lights too. That makes 8 channels... I don't have any experience with that many channels. |
#13
Thanks guys!
No I'm not on that forum, i have tried to join but it won't accept my simple hotmail.com adress.. wierd. I'll have to PM the site admin. Yea, Sabertooth is great. I have two of them in my Kyosho and also now in my 1:8. So easy to hook up and never had a problem with it. The sabertooth ESC allows you to have all driving on one stick, forward/reverse(ch1?) and right/left(ch2?) As of now i don't really know how many channels I'll use, but probably a bunch. Right now i dont have the right radio, just a simple 4ch. But after my vacation I'll order a Robbe FC16 Truck&Boat and i think a multiprop12+2 modul! same as you i don't have any experience with alot of channels, nor electronics, buy it will hopefully sort out! For today i have just done some detail welding and a new design on the bladelifter! /J |
| Thread Tools | |
| Display Modes | |
