Go Back   Scale 4x4 R/C Forums > 1:1 Rides > Cars, Trucks, Motorcycles, Boats, & Planes!
Cars, Trucks, Motorcycles, Boats, & Planes! Post anything you want on your personal vehicles!
Old 07-24-2011, 02:57 AM
maintguy69's Avatar
maintguy69 maintguy69 is offline
I'm not ignoring you. Your comment is awaiting moderation
Member Number: 8868
no worries about the chain but the tensiors are the problem with them
don't matter what year as soon a it hits 150k is when you have to worry about them
Sometimes I pretend to be normal, but it gets boring, so I go back to being myself.
Old 07-24-2011, 08:29 PM
igotit's Avatar
igotit igotit is offline
Scale4x4 is the REAL world, right?
Member Number: 3180
B/S/T Feedback: (23)
i just drove it for about 1 hour,ive determined i need to pull the head.
runs flawless with radiator cap in vent position,but when i close the cap properly smoke starts bellowing out the exhaust.once she warms up really good the throttle response is weak.
at this point it could be either the head gasket or head,or both.
im fearing the head because she runs worse as she warms up....due to metal expanding when heated....a tiny crack would open.
but still not getting water in the oil,or vise versa.
im assuming i have the rf1a t case
L45 4 speed tranny
heres a few pics of the under side!
front axel
t case
rear axel
under floor board and chasis,minimial surface rust!
Old 07-24-2011, 10:05 PM
ou812 ou812 is offline
FlatBrokeCustomz
Member Number: 2317
B/S/T Feedback: (10)
I think ya got stiffed and the seller new it
I didnt like how the seller posted pics with blocks and a piece of cardboard to lay on when he looked at something underneath,none the less I think it was still a good buy from a dishonest seller
Old 07-25-2011, 07:17 PM
igotit's Avatar
Member Number: 3180
Oh i agree.... The seller knew what was up,after 30 mins of talking to him and looking over the truck.... I knew his hustle.
I would had bought it for that price with a locked up engine.
Rot free body, working drivetrain....well worth it.
Old 07-25-2011, 08:00 PM
Ian's Avatar
Ian Ian is offline
Waiting for my free magic pen!!
Member Number: 2692
Damn, really? You fancy a Suzuki SJ then?
Nice buy! I personally think you'll be lucky and it just be a head gasket. I have my fingers crossed for you anywho.
So what colour you painting it?
01/03/1949 - 13/03/2013.. You fought Cancer to the bitter end, I'm so proud of how strong you were. Love you Dad.
Old 07-25-2011, 09:42 PM
pardonmyn00b's Avatar
I ain't not a dorkus
Member Number: 8206
I'd say paint it blue and it would fix itself, but it appears the original color was blue...I'm out of ideas.
Old 07-25-2011, 09:51 PM
gearhead's Avatar
gearhead gearhead is offline
Member Number: 2335
B/S/T Feedback: (17)
well,seing that the head might possibly be cracked? you will probably not have much use for this rig,ill come down and take it off your hands for ya
BROKE MOFO MEMBER #1
Old 07-26-2011, 12:55 AM
FlatBrokeCustomz
Member Number: 2317
I dissagree
RED would self correct all issus
blue being the dominant color of the water in the ocean.........since water is getting in the engine.....hence blue(with a lowercase)is the problem
red being 33.7% the color of fire......which is needed inside the cylinders for proper combustion
get over it man blue sucks
Old 07-26-2011, 09:23 PM
igotit's Avatar
Member Number: 3180
maybe some good news!
ive pulled the carb and intake,the intake gasket between the #1 intake valve. water port and #2 intake valve was washed out.
this allows water from the water inlet to enter #1 + #2 intake valves.
there is still antifreeze sitting ontop the intake valves.
ill still pull the head,that way i know what ive got,and do a ndt crack test,check for warpage....ect....along with some pm work.
ive ordered the rock head gasket set.....is the supplied head gasket any good?
also does the rock set come with the exhaust gasket set?
but after pulling the valve cover....the oil turned gray.....not looking good!
Tomorrow evening ill pull the head and timing setup.
Ill know more by then.
Ive got to get up for work in 6 hours.....lol.
also the 2 bbl is wired closed,just the one small barrel working.
so carb rebuild is in the future,changing all vaccum lines,along with all rubber under the hood.
i did find some rot and bad rust beneeth the battery.
this 22r has the dual timming chain.
heres a few pics!
Old 07-27-2011, 06:35 AM
bushwacker's Avatar
bushwacker bushwacker is offline
Member Number: 11703
Looks like the oil has had water mixed in with it @ some point
Old 07-27-2011, 05:39 PM
igotit's Avatar
Member Number: 3180
a few days ago the oil was deep black,ran it about 1 hour since...now gray....im sure waters getting places its not supposed to go.
Old 07-27-2011, 09:10 PM
igotit's Avatar
Member Number: 3180
got the head off....the head gasket was dry rot!
im hoping that was my problem,will check the head out tomorrow.
one thing i dont like is the pistons are rock .50 over....i was hoping stock.
cylinders are glazed but still usable.
hg washed out between 1 & 2.
suprized it ran that good.
trying to keep my hopes up about having a good head....ill find out soon.
Old 07-27-2011, 09:16 PM
igotit's Avatar
Member Number: 3180
also found some rot/rust on the cab ....under the battery,ans a few spots on the wheel wells.
the cab floor was sectioned and repaired by a body shop a few years ago.
im very excited and happy about my yota deal.
still worth the money.
i cant believe i have the legendary yota axels.....1 5/16th shafts with 30 spline,8 inch ring.....tuff little axels!
gear drive t case.......the list goes on!
Old 07-27-2011, 09:42 PM
igotit's Avatar
Member Number: 3180
are you on you way yet.....
Old 07-27-2011, 09:51 PM
rc_dirtslinger's Avatar
rc_dirtslinger rc_dirtslinger is offline
M.U.D
Member Number: 8979
I don't know if you could put it in this truck or not but I have a 1991 Yota 22R Motor that I need to get rid of if the motors in those are shot. Nice little projects you got going on!!
Originally Posted by Old Busted Hotness View Post
I have something nicknamed Sgt. Winkletank, too, but it's in my trousers
