Old 05-06-2013, 11:30 AM
ZoZa ZoZa is offline
Member Number: 20114
Default Tatra T813 8x8 TP version - 1:10
Hi
This is my second building, this truck will be a 8x8 prime mover. The scale is 1:10, so the truck will be about 860mm long. I think it's huge. I'm using only metal, all the parts are made by me except the tires, engine etc etc.. so the truck will be about 8-10kg.
my first truck - Unicat U500 disaster response vehicle:
http://www.scale4x4rc.org/forums/showthread.php?t=73463
and the trailer to my Tatra:
http://www.scale4x4rc.org/forums/sho...168#post994168
Old 05-06-2013, 11:34 AM
So this project is a test for me, I hope I can do this, I need a lot of time.. And a lot of this:
my favorite glue, of course Loctite:
Old 05-06-2013, 11:36 AM
Aluminium profils, and a little sheet for the leaf spring.
Old 05-06-2013, 11:45 AM
I'm using plastic rod ends. I hate the aluminium rod ends. They are used by the steering linkage. For the 2 front axle I will use only one servo with a linkage
Old 05-06-2013, 11:47 AM
I have the 9 tires from RC4WD. They are 2.2 tires. Diameter is 140mm
Old 05-06-2013, 11:54 AM
So lets build a Tatra
I'm starting with the rear end. The rear axle shafts:
They are 6mm steels.
Old 05-06-2013, 11:57 AM
And the housing for the shafts:
They are 14x1,5mm steel tubes with M14x1.
Old 05-06-2013, 12:03 PM
I'm building the original suspension, this is the Tatra's unique independent suspension system with the swing-axles. I love it. But this will be very costly...
(on the last picture is a Pinzgauer diff, but its the same too)
Old 05-06-2013, 12:24 PM
For a Tatra, you need a lot of bevel gears.. 4 piece for one axle, so 16 piece for a truck.. They are very costly, so now I have just for 2 axle. First the original bevel gears:
Old 05-06-2013, 12:25 PM
and after a little modifications:
They have an M5 set screw and became a little thinner.
Old 05-06-2013, 12:30 PM
I have 18 piece of this bearings. They are 19x6x6mm. I'm using FAGs, it's about 15$ per piece.. So the cost are near by an SCX. They are used by the differentials and the tube-frame.
Old 05-06-2013, 12:33 PM
I have some laser-cutted parts for helping me. With this a can make all the holes at home with a standard cheap drill. They are 1mm stainless steel.
One for the rims, one for the hubs and one for the outer "C-hub"
Old 05-06-2013, 12:36 PM
Laser cutting is a relative cheap technology, so I want to design more parts with this technology.
Old 05-06-2013, 12:39 PM
This parts are the wheel hubs. They are made of steel, without the mounting holes, cause its cheaper without them, and I want use my laser-cutted gage
Old 05-06-2013, 12:42 PM
With this parts, now I can make a complete rear axle. The bearings in the axle are cheap 12x6x4mm bearings.
