Old 01-28-2015, 09:19 AM
Jugg2Driver's Avatar
Member Number: 3
Default We build the Axial Yeti XL Builders Kit!
We are building it!!!
Old 01-29-2015, 09:04 AM
Member Number: 3
The build starts:
Working on the front diff (open)
Front diff housing and center drive shaft
Wild Boar driveshaft for the rear axle
Old 01-29-2015, 09:05 AM
Member Number: 3
The rear diff is identical to the front and it is also open.
Old 01-30-2015, 09:19 AM
Member Number: 3
Continuing the build. Working on the front end of the buggy, setting up the steering knuckles.
Be sure to not the angle of the hub carrier, the pivot pin, and the grub screw that holds the pivot pin in place. This is right side up.
Installing arms into front chassis plate.
Turnbuckles, note that there are two sizes of turnbuckles, these will be the larger set. The one in the image is actually the smaller one, but you get the idea.
Assembled front end.
Old 01-31-2015, 11:51 PM
Member Number: 3
more work on the front end - steering and chassis connections.
Old 02-01-2015, 12:40 AM
Member Number: 3
Old 02-03-2015, 09:03 AM
Member Number: 3
Moving along with the build.
Servo steering link.
Servo installed
Rx installed
Rx box cover with gasket.
ESC mounting plate and ESC installed
Special thanks to Corey over at RPPhobby.com for helping me acquire the BL system and servo for this build.
Novak Crusher 4PHD 4 Pole 4x4 SCT Brushless System
Tactic TSX45 Metal Gear servo
Old 02-03-2015, 10:16 PM
twissted's Avatar
twissted twissted is offline
early bronco nut
Member Number: 5570
Nice pics of the build. Great to fallow along.
You should try the OFNA diff lock on this build.
http://www.ebay.com/itm/Ofna-10230-D...em43d730 1b27
I'm addicted to cool even if I have to make it that way.
Old 02-04-2015, 01:21 PM
Member Number: 3
If only they weren't already all sealed up.
Old 02-04-2015, 01:30 PM
Member Number: 3
Started work on the gearbox.
Motor mounting plates and outdrive cup.
On to the slipper clutch, all the parts pictured below.
[IMG]https://lh6.googleusercontent.com/-eluv01K***w/VNGVbfu-HxI/AAAAAAAACbc/FfVpQ-Mf9Io/w800-h501-no/IMG_1075.JPG[/IMG]
Be sure to note that they kit comes with two types of friction plates, you will used the aluminum ones for this build.
Motor mounting plate.
Rear driveshaft.
All electronics and drivetrain installed.
Old 02-05-2015, 10:29 AM
Member Number: 3
Moved on the building the rear portion of the cage:
On to the swaybar
Top to the fuel tank on the cage, not sure why the instructions have you do this after building the swaybar...
Mounting the swaybar to the rear cage.
Installed on the chassis
Moving on the rear suspension and battery tray doors.
Upper link mounts
Battery tray doors.
Lower link mount
Upper links
Lower links
Links installed on axle
Installing the links on the chassis.
Upper mount
Upper and Lower
swaybar install
Old 02-06-2015, 10:58 AM
Member Number: 3
Shock time!!!
Please note that the pinstons in the front and rear are different.
Front is on the left (4 hole) and the rear is on the right (6 hole)
Mounting
Old 02-10-2015, 11:08 AM
Member Number: 3
Continuing to move forward with the build.
Roll cage
At this point I moved ahead to the wheels, the next step in the manual would be to start on the body panels but at the moment I am out of paint.
Fully assembled and rolling chassis.
Old 02-10-2015, 10:45 PM
Member Number: 3
Old 02-12-2015, 08:51 AM
Member Number: 3
Final process, the body panels are painted and decals are being applied!
Installing the hinges for the body. Make a note of the screws used here as they are two different lengths but it is unclear in the manual. (see video below)
Spare tire mount.
Done!
v
