Scale 4x4 R/C Forums
-   Help wanted! (https://www.scale4x4rc.org/forums/forumdisplay.php?f=116)
-   -   servo help (https://www.scale4x4rc.org/forums/showthread.php?t=88038)
Nikaem 03-31-2020 06:53 PM
servo help
too much input i am lost
Remote control maximum angle: 120
Dead zone: 2μs
Working frequency: 1520μs / 330hz
Working voltage: DC4.8V-6.6V
Motor: iron core
Speed 4.8v 0.12 sec/60
Speed 6.6v 0.10 sec/60
Torque 4.8v 10.7 kg.cm
Torque 6.6v 14.32 kg.cm
Weight: 60 g
Dead -band: 2μs
Operating Speed (4.8V): 0.18 sec/60
Operating Speed ( 6V): 0.16 sec/60
Stall Torque (4.8V): 16.5 kg.cm ( 582.02oz/in )
Stall Torque (6V): 21.8 kg.cm ( 768.97oz/in )
Dimensions: 40.5X20.2X40mm /1.59 X0.80X49 in
Weight: 58g ( 2.05oz )
Steering angle: 0-120 degree
what is the relavent information
heartless 03-31-2020 07:16 PM
relevant information would depend greatly on what the use is going to be.
of the two, the 2nd one appears to have more available torque.
caprinut 04-01-2020 04:38 PM
For a scale rig I would say torue is the one to look for, go after the 6v ratings.
For modern chassis like SCX and TRX-4 etc I would not recomend less than 15kg, same with a heavy ish chassis.
For a CC01 a 6.5kg + servo would work fine.
And like Heartless said it depends on the chassis and useage.
Nikaem 04-01-2020 05:47 PM
so is a 35 too much i ordered two for my old truggy
heartless 04-01-2020 08:31 PM
35 a piece? or 35 for two?
either way, not a terrible price
Nikaem 04-03-2020 11:35 PM
18 each for 35kg coreless for the truck on the right
caprinut 04-06-2020 10:16 AM
Big tires may be needing a 35kg servo.
But most of the servos rated at that is nowhere that stong.
But other than that you may need a external BEC as your now powerful servo rob the power needed for your esc and receiver.
I'm running a 25kg servo in my Hot Rod without a bec.
Working fine, but I really need to install a BEC.
When your servo dies, it's already to late to fix it.
A BEC make sure the servo is getting the power need so it won't run hot.
Hot circuit board in servos is a killer for them.
