Go Back   Scale 4x4 R/C Forums > R/C Manufacturers/Venders/Retailers > Product Reviews
Old 12-17-2018, 08:56 PM
Sadking Sadking is offline
Member Number: 26897
Default Ovonic 5000mAh 2s review
This is the new OVONIC 7.4V 5000mAh 50C 2S LiPo battery pack from Ampow. The battery features a hard case design with a 12-gauge pre-wired Deans (T-style) connector and JST-XH balance charge connector. It is rated with a 50C discharge and 100C max burst discharge rate. The battery is a standard “stick pack” with dimensions of 137mm x 45mm x 24mm and weighs in at 302 grams.
This OVONIC pack is ideal 1/10-scale off-road vehicles which use a full-length battery pack (such as short course trucks, monster trucks, and rock crawlers).
This battery pack provided ample run-time in our Traxxas 2wd Slash with a modified motor, and remains well balanced and consistent charge after charge.
Specifications (provided by Ampow):
Brand: Ovonic
Chemistry: Li-polymer
Cells Number: 2S
Voltage(V): 7.4V
Capacity(mAh): 5000mAh
Discharge: 50C
Max Burst Discharge Rate (C): 100C
Charge Plug: JST-XH
Discharge Plug: Deans Plug
Battery Weight(dev.20g): 302g
Battery Dimension: 137x45x24mm
Wire Gauge: AWG12#
Wire Length(mm): 115mm
Pros:
Very reasonably priced at only $24.99.
Plug and play with pre-wired connectors.
Clear shrink-wrapped hard case design.
Fits most 1/10-scale short course trucks, monster trucks, and rock crawlers.
Cons:
Balance plug has bulky protection clip that can make placement in the car difficult without removing it.
Final Word:
While this is not our first pick for serious competition, this battery pack works great for someone who is looking to go backyard bashing, upgrade from a NiMh battery pack, and/or looking for a budget friendly LiPo battery pack.
