Old 03-31-2020, 06:53 PM
Nikaem Nikaem is offline
Member Number: 3125
Default servo help
too much input i am lost
Remote control maximum angle: 120
Dead zone: 2μs
Working frequency: 1520μs / 330hz
Working voltage: DC4.8V-6.6V
Motor: iron core
Speed 4.8v 0.12 sec/60
Speed 6.6v 0.10 sec/60
Torque 4.8v 10.7 kg.cm
Torque 6.6v 14.32 kg.cm
Weight: 60 g
Dead -band: 2μs
Operating Speed (4.8V): 0.18 sec/60
Operating Speed ( 6V): 0.16 sec/60
Stall Torque (4.8V): 16.5 kg.cm ( 582.02oz/in )
Stall Torque (6V): 21.8 kg.cm ( 768.97oz/in )
Dimensions: 40.5X20.2X40mm /1.59 X0.80X49 in
Weight: 58g ( 2.05oz )
Steering angle: 0-120 degree
what is the relavent information
Old 03-31-2020, 07:16 PM
heartless heartless is online now
relevant information would depend greatly on what the use is going to be.
of the two, the 2nd one appears to have more available torque.
Old 04-01-2020, 04:38 PM
For a scale rig I would say torue is the one to look for, go after the 6v ratings.
For modern chassis like SCX and TRX-4 etc I would not recomend less than 15kg, same with a heavy ish chassis.
For a CC01 a 6.5kg + servo would work fine.
And like Heartless said it depends on the chassis and useage.
Old 04-01-2020, 05:47 PM
Member Number: 3125
so is a 35 too much i ordered two for my old truggy
Old 04-01-2020, 08:31 PM
35 a piece? or 35 for two?
either way, not a terrible price
Old 04-03-2020, 11:35 PM
Member Number: 3125
18 each for 35kg coreless for the truck on the right
Old 04-06-2020, 10:16 AM
Big tires may be needing a 35kg servo.
But most of the servos rated at that is nowhere that stong.
But other than that you may need a external BEC as your now powerful servo rob the power needed for your esc and receiver.
I'm running a 25kg servo in my Hot Rod without a bec.
Working fine, but I really need to install a BEC.
When your servo dies, it's already to late to fix it.
A BEC make sure the servo is getting the power need so it won't run hot.
Hot circuit board in servos is a killer for them.
