Old 06-29-2009, 03:22 PM
Racer4Life's Avatar
Racer4Life Racer4Life is offline
Just chilling and working on some scale stuff
Member Number: 1512
Default RC4WD Stamped 2.2 beadlock (other brand tire mounting)
There have been a few people ask about mounting other brand tires to the RC4WD Stamped 2.2 beadlocks. I have mounted Panthers, Axial and RC4WD tires with no issue. Here I show mounting Prolines. I think Losi are normally about like Axial beads, so thay should be okay.
It is my understanding that these are shipping now. So you can visit RC4WD to purchase them.
I have to first thank Sloppy for the idea to mount Prolines on the 1.9 Stamped beadlocks. 1BJB did a write up on how to mount other brands to the wheels.
http://www.scale4x4rc.org/forums/showthread.php?t=34794
This cost $1.75 to mount the Prolines. I first went to the Hardware store. picked up two 2" Sch 40 plastic Couplings. These have the same ID as the RC4WD rings, but have a much larger OD.
You can cut one of these down to three rings.
Then I cut the ring down to size. make sure its the same width or you will have issues with the tire pulling out. The plastic is a little bit heavier. Steel .056 Plastic .068
Then install the ring into the tire and begin to mount the beadlocks like normal. I used two longer screws to help get them mounted.
These make it much easier to mount the beadlocks.
Here is how they look before I started to tighten them.
Tighten them down one then the other and then back again. Until they are tight.
Now you can install the stock screws.
Once the 4 stock screws are in and tight you can remove the other two longer screws.
Then install the other two stock screws and tighten.
You can see that the Proline tire is nicely installed and airtight.
Hot Deals. Check it Out!
Old 06-29-2009, 03:32 PM
smm_cbf's Avatar
smm_cbf smm_cbf is offline
"Water Good When Water Proof"
Member Number: 2341
Thank you posting this, was thinking about getting some and use proline chisels.
Old 06-29-2009, 08:33 PM
Terminator13's Avatar
Terminator13 Terminator13 is offline
All mighty and strong termite. xD
Member Number: 1435
Man Tom, good writeup! But who the heck uses moabs nowsadays? :P
Old 06-30-2009, 07:31 AM
Racer4Life's Avatar
Member Number: 1512
The only thing I had laying around.
Old 06-30-2009, 07:57 AM
Member Number: 1435
haha!
Old 06-30-2009, 08:56 AM
nismotuningrocks's Avatar
nismotuningrocks nismotuningrocks is offline
crawlin it up since '07
Member Number: 2294
i wonder why
Team Nutella '09
this stuff rocks
Old 06-30-2009, 12:43 PM
adamski's Avatar
adamski adamski is offline
Tamiya Fan
Member Number: 224
I use these wheels (1.9 version) on my RPP chassied Tamiya Wrangler... they are good wheels for the price.
Adam
Old 06-30-2009, 01:45 PM
Stallion67's Avatar
Stallion67 Stallion67 is offline
Crawler addict
Member Number: 1585
I owuld liek to see someone do the 1.9 flat irons.
Old 06-30-2009, 03:50 PM
Racer4Life's Avatar
Member Number: 1512
I posted a link to a thread that 1BJB posted mounting the TD's. This should work for the FI's too.
Old 06-30-2009, 04:36 PM
Stallion67's Avatar
Crawler addict
Member Number: 1585
thanks, i had thought about trying that but then I just decided to get some rok lox instead and have 2 sets of tires
Old 04-21-2011, 05:49 PM
reddevildemo's Avatar
reddevildemo reddevildemo is offline
Demo..for short. Semper Fi to all those serving the country
Member Number: 3586
B/S/T Feedback: (9)
I know this is a long , old thread but I was wondering if anyone tried this with the new Pro line TSL's ?
Having one hell of a time getting them to seat.....if no one has I will be the ginny pig this weekend.
"There is no better friend...
and no worse enemy than a United States Marine."
Old 06-16-2011, 09:26 AM
Tommy R's Avatar
Tommy R Tommy R is offline
Geaux Tigers!
Member Number: 5478
I'm curious, too. I've got some 2.2 stamped steel wheels, but with Pro-Line TSLs I'm about 3/8" from seating the rims together. Even with a 2.2 RC4WD tire (Baja Claw) I'm still 1/4" from seating.
Maybe I'm missing something, but how does the PVC work since it still has the same I.D. as the supplied aluminum ring?
Thanks!
Old 07-29-2011, 01:40 PM
oldrtybstrd oldrtybstrd is offline
Member Number: 15757
I tried this method, it does work, but I had to cut the pipe a little bit narrower than the stock steel inner. it gave a little more room to compress the bead. I also sanded a 45 degree on the each side of the pipe to allow more room for the thick bead of the tire, seems to work. What a PITA though, took a few tries to get everything on straight., but they do look sweet.
