Go Back   Scale 4x4 R/C Forums > Gone But Not Forgotten > FreddyGearDrive
FreddyGearDrive Some of Freddy's contributions to our hobby
Old 07-03-2010, 06:38 AM
FreddyGearDrive FreddyGearDrive is offline
Member Number: 7681
Default Man! I sure miss my knight!
Built this streched knight about 4 years ago.Was going to make it a Atlas truck,but sold it before I finished it.
Ever since I sold it,done nothing but wish it got finished. So..did some diggin in my parts bins,& this is what I came up with.
Looks like time to bring my dream to reality. First cut out & drilled some nice 31"RAILS
Now the building begins,This is where she's at now.
Plan on going all out on this one,she's gunna have a car hauler on tractor & a 9 speed trany. & I know how you boys all like drom boxes,she's getting one of those also. This drom will be the same higth as the cab.
Thanks for takin a look!
FGD
Old 07-03-2010, 07:33 AM
LOSIASSOCIATED's Avatar
HD Tow King!!
Member Number: 4426
Like I said on the other sight WOW!!
Large and in Charge! HD TOW TRUCK
R.I.P. Freddy Geardrive,Richie Acosta
  #3
Old 07-03-2010, 09:56 AM
Member Number: 7681
Thanks Losi!
Some grinding,lathe work,drilling & a bit of talkin to my self,& she's a 9 spd!
This is gunna be a blast,trying to master going through the gears.
Thanks for lookin!
FGD
  #4
Old 07-03-2010, 10:13 AM
venom*one's Avatar
venom*one venom*one is offline
Member of the C.R.S.P.!!!
Member Number: 1499
here we go again... wish I had 1/4 of your extra parts...
Former Owner of BMF#1 BMF Member 21
oh killbucket, your willy is sooooooo big!!!
  #5
Old 07-03-2010, 04:20 PM
That's a lotta gears!
  #6
Old 07-03-2010, 04:45 PM
hitachi hitachi is offline
dirt mover from norway
Member Number: 12120
gonna be like the real deal with that many gears
  #7
Old 07-03-2010, 06:22 PM
truckerbuddy2's Avatar
truckerbuddy2 truckerbuddy2 is offline
Home of the XC Retirement Community
Member Number: 881
B/S/T Feedback: (20)
Nice. Bet its gona look twice as good as the first one.
Old 07-03-2010, 08:07 PM
Wheelyking4x4x4's Avatar
Wheelyking4x4x4 Wheelyking4x4x4 is offline
Member Number: 6773
thats gonna crawl in first, very cool though,also anyone know the ratios on a semi 3 speed?
Originally Posted by 2froo4u View Post
Two Higgs-bosuns and an old box of Ho-Hos aren't going to support my octopus racing habit. Mayonnaise nipples, I'm steamed!
  #9
Old 07-03-2010, 08:25 PM
Fhhhstix's Avatar
Fhhhstix Fhhhstix is offline
Just trying to keep up.
Member Number: 4430
Here are the stock gear ratios.
Low (1st) gear ratio: 1:32.49
Middle (2nd) gear ratio: 1:17.66
Top (3rd) gear ratio: 1:10.66
  #10
Old 07-03-2010, 11:23 PM
hvy 1ton hvy 1ton is offline
Member Number: 703
If i remember correctly 3 of the gear ratios will be doubles, but i'm not up for the math tonight. That aside, the project has a lot of potential and your sure to bring it out.
  #11
Old 07-04-2010, 12:24 AM
sig p232's Avatar
sig p232 sig p232 is offline
I am the Scale 4x4 R/C Grand PooBah!
Member Number: 11
You will end up with a six speed.
You will need to run a high rpm motor because your reductions are going to be insane:
1:1055.6
1:573.8
1:346.3
1:311.9
1:188.3
1:113.6
If the transmission gear ratio provided was correct. Then add an additional 1:3 reduction for the axles.
I cant wait to see the video!!
Nate
  #12
Old 07-04-2010, 02:31 AM
Member Number: 6773
sig's got a point however i think his math has gone haywire don't you add one reduction to the other? i think you multiplied there will be 9 possible combinations, however 3 will be the same
1 1 : 1/64.98
1 2 : 1/50.15
1 3 : 1/43.95
2 1 : 1/50.15
2 2 : 1/35.32
2 3 : 1/28.32
3 1 : 1/43.95
3 2 : 1/28.32
3 3 : 1/31.32
  #13
Old 07-04-2010, 08:08 AM
Member Number: 7681
Thanks Guys!
Yea,Sig & wheely,Travis & I figured it to be a six spd on the up shift. One thing guys,the pinion is a lot bigger than stock going into the second trany.
So the ratio of the second will be different from the first.As long as tamiya determans ratio off of pinion & not input gear of trany. Guess I'll find out today! Was going to lay this unit on its side,but turns out I can get away w/it upright.
She's a tight fit,don't think a set of fleas balls could fit between windshield & motor.
Can't wait to see how this all works out w/a mfu. Have a feeling the mfu won't take to this to good!
Well if mfu sound don't work right,I'll have a truck that will sound like a flippin jet.
Here's the motor I'm going to try first.
So you think 30,000 rpms will be enough??
I can't wait to get some juice to this just to see how it acts!
Again, Thanks Guys for the info!
FGD
  #14
Old 07-04-2010, 08:35 AM
Oggy's Avatar
Oggy Oggy is offline
bent stick shoot straight stick, sometimes hit target
Member Number: 3635
i was thinking this is on o.k. build until i read "9 gears", this is now an awsome build
Old 07-05-2010, 12:06 AM
sig p232's Avatar
Member Number: 11
I am going to have to stick with my calcs.
One example, the stock crawler has a gear ratio of 23:1, but if you add the optional gear reduction unit the final gear ratio is 174:1. The optional gear reduction box is 7.4:1. If you take 174/7.4 you get about 23.5.
If you are running a 30,000rpm motor with stock tires, in low-low you should achieve a speed of about 0.103302 MPH, if you follow my calcs. If you add the ratios you would be able to achieve a speed of 1.678145MPH. It should be pretty easy to determine who's calculations are correct at that point.
I am calculating a top speed of 0.95961MPH with a 30,000RPM motor.
You have an awesome build, but no speed demon.
Nate
PS, if my calcs are wrong, I will have to ask for a refund from my engineering college and they may force me to return my masters degree. If I am wrong, I will buy you a coke if we ever meet and if I am right, i will still buy you a coke.
