Old 05-07-2020, 03:05 PM
Tommygunn Tommygunn is offline
Member Number: 7655
Default Will it remove torque twist... an extra gear added to one SCX10 type gearbox output?
As the title says, will having an extra drive gear on one of the outputs(see photo), allowing the two prop shafts to rotate in opposite directions, completely or partially reduce torque twist/body roll under power?
Cheers,
Tom.
