Old 05-24-2014, 06:24 PM
BigSki BigSki is offline
Member Number: 5394
Default Casting parts
Hi everyone! Not exactly sure where to post up this question, this seems like the most logical place. I've been working on a replacement grill for the Hasbro 1/6th scale Jeeps for a while. I'v been designing, then 3D printing, parts for the project. Once I get a printed part to fit correctly I will make molds off of the part then make copies using a white casting resin. So far, all of the parts turns out really good.
I'm hitting a brick wall with casting the headlight lenses. The Printed parts fit nicely and the molds came out really good, it's just that every time I mix up a batch of the clear casting acrylic, the lenses never come out right. They are always cloudy of filled with tiny air bubbles which usually indicates that the resin was too cool. I always heat up the resins and the mold, before mixing and pouring but the end results are always the same.
I'm reaching out to see if anyone else has any knowledge about using 2 piece molds along with clear casting resins that could offer some pointers to me, or a better product for doing what I'm doing.
I've been using the Easy Cast clear epoxy designed for thin casts.
Old 05-25-2014, 02:15 PM
jeepman98 jeepman98 is offline
Too many ideas not enough time
Member Number: 16005
I am not sure about casting but you could make a mould and try vacuum forming with clear lexan, if you are only doing something small like that you could make the vacuum box for only a couple of dollars.
Old 05-30-2014, 09:48 PM
Ragnarok's Avatar
Ragnarok Ragnarok is offline
Member Number: 88
You need a degassing chamber for your resin.
Old 02-15-2015, 08:34 PM
sgl's Avatar
sgl sgl is offline
Member Number: 19298
I made tail lamp lenses for the little Bronco II in my avitar using easy cast. The few tips I would suggest are a consistent room temp I had the best luck around 70 degrees. Second nice smoothe molds. And finally I used a fair size plastic jar, used a tire valve sem with out the little valve and drew a light vacuum on it with a cheap plastic brake bleader from Harbor freight. It all helped but was still variable. Oh the mixing and stiring makes a huge difference as well. I can hunt up pictures of the vacuum container if needed.
