Go Back   Scale 4x4 R/C Forums > Other R/C and Misc > Static Models
Static Models This for you static display modelers. 1/24, 1/25, 1/18, 1/43, etc static display models, kits, pre-builts, whatever. If you got it, here's your forum.
Old 10-24-2016, 12:36 PM
Nice!
Old 10-31-2016, 06:22 AM
Rangeman's Avatar
Rangeman Rangeman is offline
Member Number: 19510
I continue to work with the sides of the box.
In the original, the sides were constructed with slats of 10 mm and 7 mm wide (approx.) I have tried to respect this provision, although that has me a little complicated execution. The slats the cut me a carpenter friend, and it turns out that 10 mm are 4 mm wide, but 7 mm, 3.8 mm. This causes a difference in level between each other profiles but far from make it ugly, I think they give a grace. The strips are glued to one another and to give greater rigidity to the joint add metallic profiles shaped "U" and an inner plate, both of homemade fixed together with screws M2X10. Fixing the plane of the box is by wood screws thread taking the "L" of the inner profile. For clarity, the photos
Start construction of the first side
I can not wait any longer and "presented" the first fragment lateral to see how it
The left side over the right course
The left back in place
And also the right
Manufacturing process of the metal profiles
Profile finished with wooden slat 7x4 mm, used as a template
The first outer profile placed
Fixing the inner profile and the plane of the box
Machining the metal profiles
Front panel of the box seen inside
Front panel seen outside the box
The side assemblies. Note the different levels of profiles
Building the folding rear lid
The cap positioned in its location
Building the hinges of the hinged lid
The completed cover, with hinges
Inside the box
The finished box, with the first charge
I'm still working on the details soon.
Greetings to all
Old 10-31-2016, 01:43 PM
Rolex's Avatar
Rolex Rolex is offline
Young Street Urchin
Member Number: 23755
That's absolutely beautiful. What a flawless job you're doing.
Old 11-20-2016, 05:18 PM
Fourth Protocol's Avatar
Fourth Protocol Fourth Protocol is offline
Keep calm and rage quit
Member Number: 23725
The restoration is incredible. The effort your father went to, to make such a toy for his four year old son is astounding. My son is four, and I'm feeling rather guilty for just buying him a Tamiya Wild Willy.
Times have changed. And I appreciate you sharing the story and the process. Mind blown
Old 11-27-2016, 11:48 AM
Rangeman's Avatar
Thank you for your comment and for visiting this thread. What I value most about this project is to be able to appreciate in detail the great work that my father did.
Old 11-27-2016, 12:04 PM
Rangeman's Avatar
Hahaha !! Do not feel guilty. Simply, as you say, times have changed. My father was part of a generation of men and women who, lacking resources and in the midst of great difficulties, achieved their goals with will, ingenuity and much personal effort. Unfortunately, it is very difficult to find these values at present.
I'll make you a confidence: The following year I had another Christmas gift. One day I'll show you, to see if you like.
Thanks for following the thread and for your comments
Old 01-08-2017, 11:09 AM
Rangeman's Avatar
Hello everyone,
It is time to finish this project, so dear to me. It has been a long process (almost 4 years), laborious and of a certain complexity, since I have had to work materials such as steel and wood that I had never worked before. The most positive part, apart from being a personal challenge for your sentimental value, is that I have counted on your interest and encouragement. This to me, is the most valuable. Thank you all for the follow up you have made of this thread, your comments and your opinions.
Now I explain how the last phase has gone.
I have varnished the cargo box. I did it with a clear varnish, to preserve the original color of the wood as well as its drawings. I added black stripes, as had the original.
The sides of the box ready for final assembly
The hardware of the box, before going through painting
And once painted
I manufacture a few chains to support the folding tailgate, with a rigid copper electric conductor
The first links
Little ones, by the way
The fastening of the chains of the folding gate
The chains, placed, support the downed gate
The indicator plates of tara and maximum weight, that are regulation in my country
The license plates
And finally I added a fuel tank. This element did not carry the original, but I think it improves the image without distorting the whole. Tell me what you think.
First steps with fuel tank
The tank with the brackets and the filler neck
The finished set
The tank painted and fixed to the chassis
After reviewing the painting, due to some scratches caused by the last work done, I can finish this project.
See you soon
Old 01-08-2017, 12:47 PM
Rangeman's Avatar
Hello again,
Once the project is finished, so that you have an overview, but also to highlight my natural incontinence when it comes to posting photos, here you have a good collection of them. If someone can not handle them at once, you can see them in two or three phases, ha ha ha !!
Comparison between the initial photo and the final result.
View from the front
Rear view
Best regards,
Old 01-09-2017, 11:26 AM
Rangeman's Avatar
January 2012
January 2017
Old 01-11-2017, 01:44 PM
Rangeman's Avatar
Hi,
On one occasion I commented that the following year I had another pleasant surprise as a Christmas gift. Although it is not a truck or car, but a steam locomotive, I think you will like to meet it.
It is an approximate 1:20 scale model of a steam locomotive of the disappeared narrow gauge railway, between Olot and Girona (Catalonia), which was dismantled in 1969.
Well, my father built it as a Christmas gift in 1952. Since at that time there was no access to the data of the steam engine, my father had told me that every day, after work, he approached the station Closer to our home and took the measurements of the locomotive on the actual model, while the passengers were down.
I put some photo Let's see if you like it.
In company of the truck Mercedes......
... and with the Range Rover
The entire collection
And now, I say goodbye to this project, which does not mean that later I hang some more photos. I want to go out to the country some day and look for some perspective to make the truck some interesting exterior photo.
See you soon. Greetings to all
Old 04-14-2017, 03:19 PM
Rangeman's Avatar
Hi,
A friend has suggested to me that a toolbox would look great on the truck. I think she is right and I have started to build it. And here you have it. I have built it with wooden slats, like the cargo box and I have put a folding door
First steps
Finished toolbox
And placed in its place
And finally I attach some photos that I have done this morning to the truck. I hope you like them !!
Old 09-24-2017, 12:13 PM
You should be proud of your fathers work as well as yours. The Locomotive is equally impressive thanks for sharing it with us. Its pretty cool that your dad was a self taught toy build as are you.
Please be sure to share any more of your fathers toy build and yours of cource.
Old 09-26-2017, 05:59 AM
Rangeman's Avatar
It is indeed a pride, but the greatest value is the fact that this work keeps alive the memory of my father and I can transmit this memory to my sons and my grandson. And also share it with all of you. Sincere thanks for your appreciation. Greetings from Catalonia
Old 09-30-2017, 05:29 PM
MaddyDaddy MaddyDaddy is offline
Member Number: 19770
Very nice work, it looks better than new!
Old 05-07-2018, 10:44 AM
Rangeman's Avatar
Hello everyone, how are you?
After a period of inactivity in the forum, I decided to visit it and I realized that the photos of my threads (stored in "postimage") do not appear.
Looking in the network for the possible solution to the anomaly, I found a comment in which it is proposed to change "postimage.org" to "postimage.cc" in the links of the photos. And it works well! The problem is that you have to do it in each and every one of the photos !! I'll see if I decide to do it, because it's a lot of work .... I already had problems with "imageshack" that caused me a lot of work in replacing the photos and now again .... !! It tires! What is your opinion?
I say it in case someone of you has this problem and this information is useful
Best regards to everyone
