Go Back   Scale 4x4 R/C Forums > In General > Scale 4x4 R/C Official Regional Clubs > Lincs R/C Offroad
Lincs R/C Offroad Home to the Lincolnshire, UK R/C Offroad club.
Old 06-29-2010, 04:24 PM
mikef350's Avatar
mikef350 mikef350 is offline
Member Number: 4007
Default cc01 advice needed
hi all
i joined this site two years ago and have only just started to have a look around this past couple of days so just thought i would say hi and wanted to no if any one no's if there is any after market scale tyres with good all round grip for my tamiya pajero and is there any mods that i should no about and is there any where i can get after market parts plus i need a rear diff locker can any one help.
mike
Old 06-29-2010, 04:27 PM
Rikk Rikk is offline
Member Number: 10558
Can't make any recommendations not having a CC01, but would be worthwhile poking around here as it's all devoted to the CC01
http://www.rccrawler.com/forum/forumdisplay.php?f=178
Old 06-29-2010, 04:45 PM
captain scale's Avatar
captain scale captain scale is offline
Captain Scale
Member Number: 870
I have some GPM front end parts for sale for the CC01, the most popular being the Ball Bearing Steering Upgrade. http://cgi.ebay.com/ws/eBayISAPI.dll...STRK:MESELX:IT
I've seen these tires used a lot on these rigs http://sdi4x4.com/product_info.php?c...products_id=59. I think for locking the rear diff there is a Mod where you simply take one of the 3 spider diff gears and place it inbetween the other 2 and it locks the whole diff. http://www.rccrawler.com/forum/showthread.php?t=240033
There are a lot of other aftermarket parts available for the CC01!
The Dually Grand Master!
https://www.facebook.com/Captainscalemodels
Old 06-29-2010, 04:46 PM
igbandy's Avatar
igbandy igbandy is offline
Member Number: 2032
without giving the pajero body a lift the largest tyre you can get under the arches are approx 90mm, I run a set of Losi MRC wheels and tyres under my pajero. Fastrax also do a set of 90mm tyres glued onto a set of 1.9" wheels.
If you give the shell a bit of a lift and trim you can go to 96mm or 98mm tyres.
Fusion Hobbies have started importing GPM upgrade parts for the CC chassis.
http://www.fusionhobbies.com/GPM-Tam...arts-s/449.htm
As for locking either of the diffs in a cc all you need to do is to either use a spare spider gear, or use of the 3 spider gears in the diff.
You have to remove the spider gear from the 3 pronged centre piece and place it between the other two gears, and it will lock the diff.
Just say no to roofracks.
Old 06-30-2010, 12:00 AM
mikef350's Avatar
Member Number: 4007
superb! cheers guys
Old 07-01-2010, 11:09 AM
mikef350's Avatar
Member Number: 4007
does any one have a cc01 propshaft,and x1 rear spring for sale?
