Old 10-30-2008, 07:01 PM
akura2's Avatar
akura2 akura2 is offline
Member Number: 506
Default ***NEW Venom Group CREEPER 2.2 Comp Crawler!!!
Venom group just released a new comp crawler!!!! OMG!!!!
locking diffs!!
weighted wheels (up to a pound per wheel!!)
http://www.venom-group.com/storeitem...&cc=MODEL_ROCK
YOU TUBE LINK!!!!
Old 10-30-2008, 07:11 PM
BADMUTHATrUCKER's Avatar
Varyag og Muspelheim
Member Number: 1018
B/S/T Feedback: (14)
Looks capable.
Old 10-30-2008, 09:30 PM
roborg5000's Avatar
roborg5000 roborg5000 is offline
Member Number: 2797
Not bad at all Too bad they were kinda stuck using the same axial green color.
Old 10-30-2008, 09:44 PM
goobs's Avatar
goobs goobs is offline
that's what she said!
Member Number: 2666
i see a lot of useable parts, but as a whole it looks kinda weird.
might get one for parts
MUTINY22 IS THE BEST!!!! chevy...like a rock!
cctc member!
Old 10-30-2008, 09:54 PM
1badxj's Avatar
1badxj 1badxj is offline
Where i am going and how did i get here
Member Number: 4135
that trans looks nice to put in a custom project. Selectable locker will be cool, wander if you could modify it to work as a dig
Old 10-30-2008, 09:59 PM
1badxj's Avatar
Member Number: 4135
just noticed it is offered in red also & 280 isn't to bad if it's the same size of the scorpion
Old 10-30-2008, 10:02 PM
1badxj's Avatar
Member Number: 4135
correction 230 is the pre-order price.
Old 10-31-2008, 01:01 AM
sloppy's Avatar
sloppy sloppy is offline
Member Number: 863
that truck so far blows all the competition out of the water box stock it has alot of great features..
full CVDS, selectable lockers, weighted beadlocks, tires look great(we all know that can be misleading) a 4 links set up with optional springs for droop, bent links, alumium caps on shocks, color options, and a great street price..
now the big question what will there parts and support system be like.. and will the aftermarket support the product..
sure would be sweet to see them do a axle only offering like axial does
http://nostr.net/forums/
Old 10-31-2008, 07:01 AM
Katan Katan is offline
Member Number: 558
Sweet! I have been waiting for remote lockable axles. I just want the axles so I can re-case them and use them on a custom build
Old 10-31-2008, 07:23 AM
UK_Andy's Avatar
UK_Andy UK_Andy is offline
www.mishacalvin.com
Member Number: 4544
This will be available in the UK through CML Distribution
Old 10-31-2008, 01:41 PM
Suicide_SAL's Avatar
Suicide_SAL Suicide_SAL is offline
Lt. Ampersand
Member Number: 2735
I donno about the shock mounting points on the axles... being bent like that will limit how you can mount them with other chassis... but the shocks themselves look really nice, both internal and external springs.
Old 10-31-2008, 03:45 PM
Slyp Dawg's Avatar
Slyp Dawg Slyp Dawg is offline
git 'er done!
Member Number: 298
looking at the axle Cs, I wonder if axial stuff (RCP clockable Cs, RCP/axial/whoever else straight axle adaptors) will fit? I definitely like the idea of remote lockers. also, it would be great if axial driveshafts (like the rear straight axles, or MIP CVDs for the front if the stock venom stuff doesn't pan out for durability) fit the diffs? I really hope these are either teh same width as axial axles or maybe a teensy bit narrower. if the axles are about that width and can handle some serious power, I'd love to try something like maybe a pair of RC4WD T1 Disruptor planetary trans, each with it's own Goat system. basically, each axle gets it's own Goat system, albeit running through something like a 9:1 reduction box. run it with a 6+ channel radio with channel mixing, have a rotary knob on the transmitter to control the mixing (read: on the fly adjustable front/rear power bias from honest-to-god FWD to honest-to-god RWD, and everything in between), then have the remaining channels for the remote diff locks. that would be bordering on the most insane scaler/basher ever, except MAYBE for thor's goat powered XC
What was it they used to say? Carrying 1 person, it's a 'Yugo': 2 people. 'Wego': 3 people, 'Wontgo' Chris
Old 10-31-2008, 04:55 PM
nataliemorgan's Avatar
nataliemorgan nataliemorgan is offline
VDub Luftwaffe Pilot
Member Number: 2469
Im diggin it! looks like a hot little ride loaded with tons of great features!
Old 10-31-2008, 06:23 PM
akura2's Avatar
Member Number: 506
from Chris Nicastro at Venom (the creeper's designer)
"Yes you can use rear steer, just add another servo mount and linkages and your ready to go. With your 6ch radio you can have independent F/R locking diffs and F/R steering, the ultimate in manuverability!
The axles are 198mm from hex face to face.
Chris"
Old 11-01-2008, 05:23 AM
Member Number: 558
Is that wider than Axial axles?
I think it is.
