Old 03-10-2020, 04:08 PM
scaleraddict scaleraddict is offline
Member Number: 20917
Hi!
I'm on the final stretch of this bed.Just need to glue the planks of the seat and make the chassis mounts
Anyway, there's how it looks:
Closed latch
A printed hinge.
I'm very excited how it turned out.Anxious to get it on the trails
  #77
Old 03-10-2020, 08:51 PM
Oh man tarp lady did a hell of a job, and double stitched
Old 03-14-2020, 08:30 AM
Because the truck has to function properly,I've improved the rear shocks to handle the extra weight.
The old ones weren't shock absorbers at all, were pretty and scale but there was no o-rings on the shaft so they couldn't hold the oil.
So , found these 60mm shocks for cheap and took the springs out and filled with 1000 oil:
They only problem is that they are made for m2.5 hardware and couldn't find 4.8mm balls for m3 so did these ones:
Don't like them upside down but unfortunately,this was the only way to mount them...
Another detail that was buggin me was mounting this tow hitch
Got the hitch from eBay, some M2 scale bolts and printed the frame around it
Don't mind the rust. It's almost ready to be painted
Old 03-23-2020, 12:05 PM
Well,guys,in my opinion, 3D printing is cool but when we only print scale acessories, we're just scratching the surface of it's true potential
The Moose axles being released free maybe clicked in my brain and came back from an old idea of making a full axle for the unimog. The problem is that I like this truck but the ugly axles seem out of place. Adding to that the front axle is a Frankenstein that i don't know how it never failed
So,I've started to design from scratch,heavily influenced by the now discontinued SSD D60 axle housing.
This housing will have all the features of the old one like being 20mm narrower to compensate to portal boxes,panhard mount, spring perches,spherical ends, 7 of caster and 3rd link mount. The pumpkin is small as the stock gears allow...
Front:
back:
Diff cover will be designed next....
Old 03-23-2020, 06:00 PM
looks awesome! well done.
Old 03-25-2020, 07:21 PM
dremu dremu is offline
I like to make things.
Member Number: 28889
Your work is so next level as compared to mine. I bow to you
-- A
Old 03-30-2020, 09:37 AM
thanks!
-- A
Thanks! well, there's no way to compare both works. I don't think I'm very skilled, only tackle one problem at a time
progress on the axle:
Like the Stones said: "I see a red axle and I want it painted black"
more subtle...
Old 04-12-2020, 11:42 AM
After more than a year without trails,finally did it!!
Took the JK, the M548 and the 'mog to drive a little. Ended driving the Unimog a lot more than the others
Tried an easy line with sucess and was doing slightly harder lines and the truck was doing great...ended in one that I was positive that will fail...but the truck managed to climb. In 1st gear of course
