Old 06-22-2011, 02:31 PM
puryear's Avatar
puryear puryear is offline
http://www.varcoffroaders.com/
Member Number: 3810
Default build ideas/ suggestions
i was wanting to build a truck and trailer to haul my hilux. the only problem is that all of the 1/10 scale full sized trucks look too small in comparison to the hilux.
i was thinking of just building a 1/8 or 1/6 scale truck to pull the hilux but, despite my search, i can't find any pics that compare the two.
does anyone know of any sources or pics, or have any comparison pics that they could post up?
thanks,
dave
CENLA
Old 06-22-2011, 03:40 PM
The Stray Cat's Avatar
Everybody Needs Rock N Roll
Member Number: 4514
B/S/T Feedback: (45)
I don't have any pics but I can tell you 1/6 will be to big and look silly also. 1/8 would probably be your best bet. See if yo can find a 1/8 newbright JK with a hilux in the pic. The JKs are 1/8 scale
Old 06-22-2011, 03:52 PM
puryear's Avatar
Member Number: 3810
i have a 1/8 jk body and it's way too big compared to the hilux. plus, i was wanting something that could really haul a trailer with a hilux on it, like a full size pickup.
the problem seems to be that when a manufacturer says a body is 1/10 scale, or whatever, it oftentimes isn't.
i guess it would be a 1/8 pickup body that i'd need to find though, but i've worked with so many 1/10 scale bodies that i've never really thought about what's out there in a 1/8 scale truck.
CENLA
Old 06-22-2011, 03:58 PM
Member Number: 4514
I have te same issue. If you look at HPIs lexan bodies, the ones they consider 1/8 and the 1/10th ones seem in scale with each other side by side, so are they all 1/10 or 1/8. The Hilux body is big compared to other 1/10 trucks I've seen that in group shots of scalers.
Old 06-22-2011, 04:03 PM
puryear's Avatar
Member Number: 3810
yeah, i believe i'd lean more towards 1/8 scale as far as the hilux. i'd like to find a 1/8 scale silverado or dodge ram body, but i'm not sure if they even make them or not.
CENLA
Old 06-22-2011, 04:10 PM
pardonmyn00b's Avatar
I ain't not a dorkus
Member Number: 8206
Hilux is 1/9 scale. I know this doesn't anyone, but I thought I'd throw it out there
Old 06-22-2011, 04:17 PM
puryear's Avatar
Member Number: 3810
well then, if there's a 1/8 scale harbody full size truck, then it should still be pretty close i'd think.
CENLA
Old 06-22-2011, 04:18 PM
Member Number: 4514
I can tell you the only Dodge Ram that's Hard body is too small. There are some old 1/6 scale ones that pop up on ebay every so often, scalerlover made a truck out of one. Other than that the only Dodge bods are HPIs Dodge Ram "1/8" or Prolines which are fairly small and not very nice looking.
Old 06-22-2011, 04:25 PM
puryear's Avatar
Member Number: 3810
yeah, a guy in our club had the dodge ram body that i think you're talking about. that thing is way too small.
CENLA
Old 06-23-2011, 04:11 AM
tamiya cc-01's Avatar
tamiya cc-01 tamiya cc-01 is offline
I`m a country boy. Got a 4wd.........
Member Number: 15013
Why not a f-150 body?
http://www.newbright.com/product/view/id/131 1/8 scale
Pajero rulzz!!!
Old 06-23-2011, 10:17 AM
Scalerlover's Avatar
Your Friendly LHS Employee
Member Number: 6476
Yeah the 1:6 Dodge was huge, and even bigger after i quad cabbed it
Unfortunately i deleted all my pics after selling everything so i couldnt reminisce.
That 1:8 F150 is ok, its just smashed height wise a little bit, making the proportions look funny.
Broke MoFo Member #41
Old 06-23-2011, 04:06 PM
puryear's Avatar
Member Number: 3810
but i wonder if it's fairly proportionate to the hilux.
CENLA
Old 06-23-2011, 09:06 PM
Member Number: 6476
Its been a while since i had mine, but i would say its fairly close, other then being longer. Its right at a 13" wheelbase...
Old 06-24-2011, 03:41 AM
puryear's Avatar
Member Number: 3810
that's what i mean though. a 1:1 f-150 is quite a bit bigger than a 1:1 hilux.
when i say proportionate, i'm meaning the way the two would compare as 1:1
CENLA
Old 06-30-2011, 12:04 PM
Xporter Xporter is offline
Member Number: 13183
I'm working on a 2wd project with an older Newbright F150. I think this body is fairly accurate and the dimensions might be what you're looking for. I'll be starting a build thread on this soon.
