Old 10-07-2016, 06:30 PM
scaleraddict scaleraddict is offline
Member Number: 20917
Originally Posted by scottyk View Post
Awesome! where did you find the little Arnold? lol
It's from Neca, from their Terminator series
Old 10-09-2016, 03:03 PM
I didn't show the functional hatch yet[/b]
Try to do the weatherstripping on the windows:
Now needs a new coat of paint to hide the excess glue
Now,the portals. A full year has passed since I've made the prototypes. I've realized that 3d printing would be the way to go and with the 3d skills of a real designer we've came up with this:
I prefered make them for yotas but right now can't afford 3 new axles
Old 10-12-2016, 04:56 PM
continuing with the portals...
narrowed shafts that came from another project
The rear ones, mounted on SSD housings
Stock shaft on top vs. portal shaft. Width stayed the same
Old 11-03-2016, 08:16 PM
YYCADM YYCADM is offline
Member Number: 24991
Those portals are amazing! I would LOVE to give them a try...are the files available anywhere to download?
Old 12-07-2016, 04:21 PM
Hi..
Thank you. The files are not available online. Was a design that I and a friend made from scratch.
Unfortunately, I've already broke one. Changed the design to be stronger and will be printed in carbon fiber reinforced filament
Old 01-21-2017, 04:01 AM
Hi guys,
well, I had the first headlights for the 'mog 3d printed but they weren't 100% what I wanted, so armed with recent solidworks skills I tried my best to replicate the real ones:
They turned out alright
IMG_20160615_193259
IMG_20160615_193328
Some aluminium foil to spread the light
IMG_20160616_113125
I think they look better..
IMG_20160617_113854
IMG_20160617_113908
They're mounted on a new bumper that's exactly the same as the old one. Had to make another because I'd took it to the shop, painted it and someone lost it somehow. Probably thrown into the trash
Old 01-22-2017, 12:34 PM
Wombii's Avatar
Wombii Wombii is offline
Styrene apprentice
Member Number: 5663
I have a soft spot for unimogs. Nice work! Would love to see a shot of the insides of the portals. Where did you get the gears for them from? How thick styrene did you use for the body, and what did you use for windows?
Old 01-22-2017, 12:51 PM
Hi,
Thanks!
About the portals, I don't a any photo of the inside but it's pretty simple, a 12t and a 25t pinion(32dp,5mm bore from hobbyking) and 4 bearings
I use pvc for the body, 3mm, I think...
The windows are made from 2mm policarbonate
Old 01-26-2017, 03:39 PM
A small clip of the first test with the portal axles
Old 02-13-2017, 12:39 AM
well, let me share the latest updates. I was delaying the new chassis for several reasons. One day,after work, had one of those "now or never" moments,blueprints in hand and 10m later:
Looked out of scale, made of 16mm tubing but the 1:1 blueprints showed 17cm frame rails so it will work out
Got a Helios 2sp a while ago on a deal and even if it's a small size 2sp gearbox, that size don't allow being on many builds. This 'mog has plenty of space for one.I don't really need 2sp but I dig the scale looks of it
In my current chassis, used a Scx10 skidplate but the new one has to be custom to accommodate the Helios.
At ride height
Sorted out the links mounts. Not pretty but was the best idea
IMG_20170131_132754
Old 03-01-2018, 02:35 PM
Hi guys!
I don't updated this for a while but it's slowly going forward, one problem at a time.
Well, my new chassis has new link mounts so I have to reduce all the links. Also, the Helios it's longer than the previous transfer box so I needed shorter driveshafts. I could cut mine but my buddy The Gamer needed longer ones and we made a trade
The axles weren't really finished. There was some rubbing inside of the portals and against the rim. The rims only needed a bit of machining. Pretty tight,eh? :
Now I have 2 rear axles looking like this, no frictions. Pretty smooth, actually
The front parts are a different history. The steering was kind of limited because the dogbone cup was binding on the inside of these axle ends.
On the left, stock. On the right, what I had to dremel to solve the problem:
And how it looks without the axle housing:
For the chassis, wanted better looking rear shock mounts than the previous
Some Unimogs are like this:
my take on them:
Had to invert the location of the shock/spring because of the sxc10 axle. Uses a long scx10 spring and these nice 60mm shocks:
Already has all the links(i know, Unimogs don't have links...)
Forgive me the lack of torquetubes with photos of ground clearance
Old 03-03-2018, 07:01 AM
Did the motor mount:
How low the motor sits...
This engine bay need lot of work but is doable. Was my first scratchbuilt body and my skills improved since 2014(or I'm more confident of being capable to do better stuff)
How the truck sits right now. The cab needs to be 15mm lower. Was on top of the rails on the photo...
more goodies coming!
after the motor mount, I want to make the truck standing on it's own so the work order is: front axle truss, panhard and upper link and spring/shock mounts
The truss
Started with the axle springs mounts, similar to the 3d printed i have in the back but in steel to be welded
Added a 5mm square steel rod,tight to the housing
To finish, the panhard mount next to the knuckle and the angled upper link mount
The idea behind the truss was making it low profile so it wouldn't hit the frame rails but in the same time, looked from factory. The angled link mount allows to use straight rods and has a thread to avoid the "nut and bolt"
Old 03-06-2018, 02:09 PM
My goal of making the truck stand on it's own is done
Finally did the spring mounts:
In place:
Next, secure the bumper
Old 03-09-2018, 02:09 PM
I have mounted the bumper,panhard bar and i'm working on the steering,this week I should have photos. Meanwhile, at home, was taking care of the bed
It's first iteration was made mainly in balsa wood, sounded like a good idea at the time:
Painted, looks good enough but can't handle the trails
So,had to do another and using the opportunity to make it wider because that was another mistake I've made. So, this one is 30mm wider
First, the bottom:
And then, one side:
Back:
With primer:
It's the first time I've worked with tooling foil. It's fun stuff
