Go Back   Scale 4x4 R/C Forums > Other R/C and Misc > R/C's For the Sea
R/C's For the Sea Ships, Boats, Subs! If it belongs in the water put it here!
Old 05-28-2015, 07:10 PM
igotit's Avatar
igotit igotit is offline
Member Number: 3180
Heres a vid towing 300 lbs
13ft pirouge plus 2 passengers.
My 30 in tug is a true work horse with 3 hour run time pulling a load at 3/4 throttle
Watch "Atlantic harbor towing" on YouTube
https://youtu.be/GZHAWllj_kQ
Old 06-06-2015, 10:46 PM
knightcrwlr knightcrwlr is offline
if its clean keep it inside the box
Member Number: 22979
Hey igotit
Long time no see lol
You know me from the other forums
I have seen your video you and your gf being pulled by your tug lol
Do you think this bb will be able to do that?
Can you help me out with parts i needed?
Like motor and esc probably a driveshaft and a prop?
Old 06-08-2015, 07:43 PM
ou812 ou812 is offline
FlatBrokeCustomz
Member Number: 2317
The BB will outperform igotit's tug,i have a 65mm wheel going on here with a 750 size motor and 4:1 reduction.It should outperform it anyway.I have a long way to go on her.
Old 06-08-2015, 08:05 PM
igotit's Avatar
Member Number: 3180
Ou812s setup will out pull my tug,he has enough power on tap to sink his bristol bay easily.
I built my atlantic for scale performance.
I used a 55t motor,3:1 gear box made from a wk tranny,55mm 4 blade.
The prop,shaft and sterntube can be had from ebayw or any uk supplier.ill try to get a link...but around $35 shipped should cover that.
Old 06-08-2015, 08:11 PM
FlatBrokeCustomz
Member Number: 2317
Cornwall models has everything needed,excellent to deal with.
