Go Back   Scale 4x4 R/C Forums > Other R/C and Misc > R/C's For the Sea
R/C's For the Sea Ships, Boats, Subs! If it belongs in the water put it here!
Old 09-29-2013, 01:30 PM
igotit's Avatar
igotit igotit is offline
Member Number: 3180
Default rc house boat slow build
for years ive wanted a rc house boat,i think its time I give it a go.
ill try to fully furnish the interior,beds,kitchen,bath...ect.
some of you guys will hate me for this....but im using a vintage lindberg chris craft sport fisherman hull.
I have the lindberg kit....but most of the parts for the kit are brittle and falling apart.
but the hull is solid.
hull is around 30x9...just the size im wanting.
heres a quick drawing of what im wanting to build.the layout may change,bathroom may be moved into the kitchen area,to allow room for living area in the wheel house.
house boats like this usually run twin mercruiser units....I don't have that option....so standard shaft and prop drive will be used.id love to get my hands on the small graupner stern drives though.
Old 09-29-2013, 02:47 PM
igotit's Avatar
Member Number: 3180
ive revised the drawing,also added 2 more windows...not pictured.
Old 09-29-2013, 03:32 PM
Small Factory's Avatar
Small Factory Small Factory is offline
Screamapillar
Member Number: 13559
I am going to love you for this...
Old 09-30-2013, 12:43 AM
cycleguy cycleguy is offline
Member Number: 20920
+1, looking forward to seeing more.
Old 09-30-2013, 09:48 AM
DRW-FJ40's Avatar
DRW-FJ40 DRW-FJ40 is offline
http://wolfcreekrcpark.com/
Member Number: 12061
cool project. I love building boats.
A quick thought on the hull. You could coat it with mold release & use it like a plug... lay fiberglass & have a mold. A lot of extra work but you would end up with a glass hull & a mold that you make more.
I've got an idea for your merc outdrives... I'll PM you.
Old 10-03-2013, 02:47 PM
Nick Furia's Avatar
Nick Furia Nick Furia is offline
Member Number: 874
Old 10-03-2013, 05:25 PM
grumpygrady's Avatar
grumpygrady grumpygrady is offline
just old and not posting just to post
Member Number: 3380
at your local dollar store look for an inflatable boat with a outboard on it they are under 3.00 dollars two or three of these motors would work ok
but they would not be fast , if you want fast then the electric outboards from kyosho tunnel hulls would work but cost lots of cash
ol yellow is what started it for myself and son long long time ago and far away
Old 10-03-2013, 09:15 PM
igotit's Avatar
Member Number: 3180
If I want speed...I have 2 ep1's with upgraded hardened gear sets.
Ill just leave it as is for now,figure something out later for scale stern drives.
I might install 1 ep1 outboard,instead of the shaft through the bottom it has now.
Old 10-05-2013, 03:24 PM
igotit's Avatar
Member Number: 3180
some real house boats down here,most are self made from steel.
this is the design im sorta after,v hull...lots of room.
Old 10-06-2013, 03:41 PM
igotit's Avatar
Member Number: 3180
Heres what I got to work with.a beat 30x9 abs hull.i think the prop is 40mm,kinda big.
Old 10-06-2013, 03:53 PM
Member Number: 3380
o you have the prop and shaft so all you need is motor or motors and rudder
this will be very nice when you get done
I can post links to pages for boat building if you need them , they are mostly for towboats through
Old 10-06-2013, 05:50 PM
igotit's Avatar
Member Number: 3180
I have a rudder,55t motor will make a coupling.
may 1.5 :1 this thing.
gotta order styrene though.
you can post links if you like,maybe we can make a sticky in the boat section.tips,tricks,and how to.
Old 10-09-2013, 04:47 PM
Member Number: 3380
the first one has all of the how to pages
http://oldriverbillzumwalt.members.k...s_&_shafts.htm
http://towboatjoe.tripod.com/shafts.htm
this one has parts and kits
http://www.vac-u-boat.com/
Old 10-13-2013, 04:18 PM
igotit's Avatar
Member Number: 3180
I went 6 family dollar,and dollar stores this morning......couldn't find a single boat outboard .....not even a windup toy motor.
I need it for another project.
Old 10-13-2013, 06:05 PM
How big do you need the outboard to be?I know of a cheap rc toy for $15 that might work with a little time and styrene.
I ordered one just to use to tow bobbers out to set up a course for my 7009.I haven't received it from Bangood yett, but I should be able to measure or provide better photos.I know its just a cheap toy, but I'm new to rc so I just wanted to post it in case you see any parts that could be useful building a better outboard.
