Old 07-02-2019, 08:54 AM
Originally Posted by frizzen View Post
If the windows aren't wanting to play nicely, maybe replace with some 0.020 to 0.040" clear lexan?
The original windows are shaped to fill the inside of the window frame instead of sitting behind it like a flat piece of lexan would do, but going with that might still be better overall if they all look the same. I'll try to come up with a way to mount them without permanent glue so I can test different setups.
  #122
Old 07-03-2019, 02:47 PM
Trust nothing, test everything, and even if you tested it, something will ruin your day anyway. A pen I used to draw up the door panel lines is now bleeding into the final coat of glossy clear. Even the red Tamiya paint is bleeding a bit because I went way too heavy on the clear trying to get a smooth finish.
To be clear for the accident report: The pen lines are bleeding because I didn't test it with the clear coat. The red is bleeding because I significantly overdosed it with solvents from the clear coat.
Old 07-04-2019, 07:17 PM
Looks like the ink floated to the top of the clear coat, so most of it could be removed with light sanding. The red paint is deeper, so I might have to live with that small flaw.
Mirror mounted reverse lights (?)
Warm white 3528 LED glued to transparent plastic inserted into a 6.3mm outside width square styrene tube. Inside filled with more glue and a 2mm thick piece of styrene glued to the back. Mounted to the mirror with a piece of a paper clip. The wires are harvested from a broken HDMI cable. They're very thin, feels like about half the size of the 28awg wire I've used for the other lights, and I'm not sure if I'll be able to crimp connectors to them.
Old 07-11-2019, 10:41 AM
Milestone: All cab lights wired up for the first time.
Connections for cab dome lights and visor lights.
Sure, I could cut the wires shorter, but then I wouldn't actually be able to get my hand in under the cab to connect them.
It works! Does it look okay with the rear side window rolled down a bit? Should I cut it down lower?
Old 07-13-2019, 07:32 PM
Firemen are such shiny happy people
I think the window looks fine, maybe run with it until you convince yourself either way about it.
Old 07-18-2019, 06:30 PM
Minor update.
Did a very rough trimming of the inner rear rims and painted them black so they look more like brake drums.
Old 07-19-2019, 12:05 AM
I think the window looks great. He's hot, but won't be in the truck THAT long to bother dropping it more.
Cool idea on the brake drums
Old 07-31-2019, 04:33 PM
Some clips from the first test of the roof monitor and pump mounted on the truck. Seems to be sucking air somewhere, possibly the filter on the supply side. Nozzle also needs some work.
The pump is currently drinking about 2.5 liters per minute.
edit: if you're as easily entertained by flashing lights as I am, here's a minute of flashing blue lights:
Old 07-31-2019, 10:09 PM
Aside from the possibility of air leak, that works extremely well I'd say. Is it the apprentice fire-fighters job to roll out the plastic at the scene each time?
Just teasing, good thinking to help protect against accidental soaking.
Old 08-13-2019, 05:11 PM
That so cool, i'm glad it's coming together. Yay flashy lights!!!
What size is the orifice on the water nozzle? To me it's looking like rather than air, you're seeing the pressure pulses from the pump impeller. Making me think you either don't have enough line acting like accumulator, or the exit hole is too big to be a 'squirt gun'.
Old 08-14-2019, 08:19 PM
Good observations. It's a combination. The first clips are careful testing with low speed on the pump which gives a lot of pulsing from the diaphragm pump. There was also a lot of air bubbles coming through the lines, most likely originating with the gas filter it was sucking water through to protect the pump. The last part of the video is full speed with the air issue mostly under control. I think I'd try going with a pair of gear pumps next build, but the pulsing is okay at high speed. If I remember correctly, the nozzle hole is 1 or 1,5mm with a cone shape to break up the stream. The inner nozzle is inside a larger 6mm (?) pipe to then guide the stream into a narrower shape. I'm not done experimenting, but this seems like the way to get something resembling a scale stream. I tried going narrower on the orifice to force more of a vaporisation effect, but kept blowing out the connections because of the pressure.
Edit: my design based on the design described on page 3 in the pdf brochure for the rm60c linked in the opening post. On the real thing the outer pipe can slide back to let it spray wide or slide forwards to force the spray down to a narrow jet. I wanted to try that, but there's no room for the servo or mechanics. It does sort of work if I adjust it manually though.
https://www.veljeksetkulmala.fi/uplo...i.original.pdf.
It really is quite difficult to make water behave properly in small scales. I never appreciated the precision required in simple things like shower heads or garden hose nozzles until I tried to make a nozzle myself.
another edit:
When I thought I was really clever and made mounting pins for the steps and the mirror lights from paperclips I forgot to think ahead. Those paperclips I used are carbon steel and will of course rust pretty fast. Especially when there's a big water sprayer on the roof.
