Go Back   Scale 4x4 R/C Forums > Monsters, Scale 4X2, & Non scale R/C > Tips, Tricks, FAQ's
Tips, Tricks, FAQ's Questions about the monsters? Ask them here! Got a great "How to" post it here!
Old 02-13-2010, 07:10 AM
SmallHaul's Avatar
SmallHaul SmallHaul is offline
"No load too small"
Member Number: 8761
Default Converting servos 360 degree continuous rotation
Some people have asked me about converting servos to 360 degree continuous rotation so, I thought I would give explaining it a shot.
Think of a servo as a 200:1 gearbox that has a potentiometer (pot) that turns with the final output shaft and the shaft has a physical "stop" on it so that it can only rotate 180 degrees or so and there is an electronic speed control that is regulated by the position of the pot.
Now to convert the servo so that it runs continuously to be a winch or to drive a wheel You need to do 3 things.
1) Remove the physical stop that prevents the servo from rotating continuously. On metal gear servos there is usually a metal pin stuck in the output gear that needs to be pulled out or cut off. Most servos with plastic gears just have a little plastic nub that needs to be cut off.
2) Eliminate the physical connection between the pot and the output gear. Some servos are easy to do this because they have a little clip inside the output gear that the pot shaft sits in that moves it. On a servo with a clip you just push the clip out through the bottom and that step is done. Some mini & micro servos are more difficult though because the pot shaft is what the main output gear actually rides on. So, in this case the end of the pot shaft will be keyed. You just need to cut the keyed end off but, MAKE SURE you don't let the shaft get hot enough to melt or damage the pot or its mount! Make sure the servos runs smoothly before final assembly to make sure you didn't cause the gears to bind at all when you cut the pot shaft.
3) Lock the pot into one position. power the servo up and set your trim on your radio to neutral then rotate the pot until the servo motor stops turning. Then glue the pot shaft so that it won't move.
Here is a link to pictures that might explain it better:
http://www.societyofrobots.com/actua...ifyservo.shtml
If you have any old or week servos laying around take them apart and convert them for practice.
Good luck!
Scott
Old 02-15-2010, 08:23 PM
Waterboy's Avatar
Waterboy Waterboy is offline
I think I suffer from something.
Member Number: 10658
B/S/T Feedback: (9)
thanks scott! great tip
W@T3R8oY wUz H3R3! Well, im Broke MoFo #89!! Eat that Lauer!!
Im suffering from RC addiction. Oh it hurts so good.
Old 02-28-2010, 03:54 AM
muddin98jeeptj's Avatar
muddin98jeeptj muddin98jeeptj is offline
Member Number: 2752
could the servo be used as a winch by doing that ????????????
hey all i have a dell laptop and tomtom one version 3 gps i will trade for a rc rtr (with everything)
prefer bruiser or hi-lift but will consider other rc let me know
Old 02-28-2010, 07:03 AM
SmallHaul's Avatar
"No load too small"
Member Number: 8761
Yes, all of my dump trucks use a modified servo used as a winch to raise & lower the dump bed.
Scott
Old 02-28-2010, 11:32 PM
holycaveman holycaveman is offline
Lack of Time'r
Member Number: 1711
Cool vid!!
Yes servo's actually make much better and stronger winches than the winches you can buy.
You can mount the servo most anywhere, then use brake line to feed the winch cable through. You can even bend the brake line around objects in your truck, to route the cable to the front of your bumper or rear.
Also servo winches will walk abit. So its best to place a power on/off switch located on your truck somewhere. So when you use it, just flip the power switch on, then work the winch from your radio.
If you use a 3 pos switch and a y harness on your truck, you can work two winches (front and rear) by the same channel on your radio. So basically only a 3 channel radio is needed for two winches, steer, and throttle. Or by the same standards, a 2 channel radio can be used for a winch and steer and throttle.
Sorry, getting off track LOL
Old 03-10-2010, 01:32 PM
Tanqueray's Avatar
Tanqueray Tanqueray is offline
Member Number: 7542
quick question, but how many ounces are you using as servos for winching?
Old 03-10-2010, 08:46 PM
SmallHaul's Avatar
"No load too small"
Member Number: 8761
The servos used on my tonka dump trucks are 40oz (torque) servos and the ones on my crane are 200oz servos.
Scott
Old 10-23-2010, 08:04 PM
madman1983 madman1983 is offline
Member Number: 13092
Thanks scott, you were very helpful
Old 02-22-2012, 12:02 AM
sgtsteve's Avatar
sgtsteve sgtsteve is offline
Member Number: 3309
I realize this is an old thread but I wanted to give a shout out to a new product that takes care of all the work that goes into making a servo winch along with some really high quality parts. Check them out.
http://www.scale4x4rc.org/forums/showthread.php?t=67056
Old 04-13-2012, 01:43 PM
peeprox's Avatar
peeprox peeprox is offline
Master of the garden shed kingdom
Member Number: 696
I've forgotten the specifics, but I know that if you're ok with a soldering iron you can replace the potentiometer with two resistors so long as they're the same resistance, both from the central leg of the pot, one to each outer leg. A pot changes the resistance between the two outer legs in relation to the center, so by replacing it with two resistors of the same value you get something that fools the board into thinking the pot is perfectly true, and will result in no 'walking'. It's the cleaner and more reliable solution, and saves you from messing around with getting the pot perfectly center and trying to stop it from being keyed to the final drive of the servo by removing it completely.
Old 04-20-2012, 02:11 PM
lilbandit85's Avatar
lilbandit85 lilbandit85 is offline
Member Number: 17747
hey does anyone have advice on how to pull the final gear off the pot when converting metal gear servos?
Old 09-10-2012, 08:40 AM
braq's Avatar
braq braq is offline
too many projects
Member Number: 12917
Default some thoughts
Hi,
I have found that with the two resistors you actually have to stick very close to the total value of the original potentionmeter, which typically is 4.7K Ohms. So a pair of 2.2K Ohm Resistors did work well, but 2.7K send the motor controller into madness.
The creeping or walking is actually a feature of the servo in it's original design to show as little deviation from the desired position as possible. You can only get rid of it by either:
i) trimming
ii) increase the deadband of the controller > either change the programm code or if it relies on an external capacitor increase it's value (take a 0.1uF Cap and try out in parallel to the existing caps on the board)
Glueing the pot, or replacing it with two resistors does not widen the deadband of the servo controller circuit (!)
cheers
braq
Old 09-13-2014, 07:42 AM
SmallHaul's Avatar
"No load too small"
Member Number: 8761
Originally Posted by holycaveman View Post
Cool vid!!
I was just reading through these posts again and using brake line or brass tube to guide the cable is a great idea.
Scott
