Old 07-22-2008, 03:29 PM
Mr. Pink's Avatar
Mr. Pink Mr. Pink is offline
think pink
Member Number: 1604
I use sullivan "gold-n-cable" with my lockers.
http://www.scale4x4rc.org/forums/showthread.php?t=18636
I also think it might be possible to convert a TLT-axle with my solution.
Need to drill a hole in the axle in the same position as on the High Lift.
/Mr. Pink
Old 07-23-2008, 06:30 AM
Rikpal's Avatar
Rikpal Rikpal is offline
Administrator - The forest dwelling drunken hobo. I'm ugly and stink
Member Number: 6
Thanks
Mr.Pink I'm using gold-n-cable too, but mine seems to be bigger than yours. I preferred that cause the little one doesn't give me the idea to be strong enough. Maybe I was wrong
Very nice work on your HL. Simple and clear. I like a lot the idea of the lockers actuated by the shifting servo.
It could be a good solution if I'll run out of channels
Rik - The Italian Guy
www.scalersandcrawlers.it - "THE" Italian Scalers and Crawlers Board - http://rikpal.golem100.com - [email protected]
If you have an apple and I have an apple and we exchange apples,then you and I will still each have one apple.
But if you have an idea and I have an idea and we exchange these ideas, then each of us will have two ideas.
G.B.Shaw
Wannabe member of MtTABRA (More than Three Axles Big Rig Association)
Old 07-23-2008, 03:54 PM
DrKucho's Avatar
DrKucho DrKucho is offline
Member number 404 , what's that? Member not found?
Member Number: 404
wow didnt see this tread ! awesome work , the system is very similar to the modification that hafner does for robbe axles, the problem of robe's is a spider gear gets weaked and might break , i already broke one ... this looks much stronger
Old 07-24-2008, 03:45 AM
Rikpal's Avatar
Member Number: 6
Thanks Doc
I hope to test it soon...
G.B.Shaw
Old 07-24-2008, 05:53 PM
Very nice, Rik. Clean, simple and neatly done
Old 07-24-2008, 08:36 PM
Tzi Tzi is offline
Member Number: 897
nice....very nice
Old 12-03-2008, 03:34 PM
lowslowTJ's Avatar
lowslowTJ lowslowTJ is offline
Now with questionable at best engineering skills
Member Number: 1051
Rik, How are these holding up under abuse? thanks for this and other awesome ideas!
Old 12-04-2008, 03:40 AM
Rikpal's Avatar
Member Number: 6
Well I have to admit I didn't test them seriously. I used them in a GTG and they seems to work fine for a while, but there something to solve with the cable and the actuators... after some time I could lock the diff only with my hands and not with the servo.
I just had an idea that could solve the problem, but I have to build it before I can tell ya something.
I wouldn't use this system with 2.2s though...
G.B.Shaw
Old 12-04-2008, 08:43 AM
lowslowTJ's Avatar
Member Number: 1051
Thanks for your response!
Do you think the strength could be increased with three locking "teeth" from the collar to the side gear?
My thought was that if I could somehow lock and unlock just the rear differential in my CR01 (2.2s) I could then use another servo to control cutting brakes right or left. So this would then make the steering work better similar to front DIG (for crawling). This would happen by locking or braking the inside rear tire. It was just a thought and may not be practical (2 servos = 4 channels), but it could use small axle mounted servos if there is room rather than the cables.
Old 12-04-2008, 08:52 AM
Rikpal's Avatar
Member Number: 6
That's a great idea, but consider that you'll have the front wheels spinning at different speed from the free rear one...
I think the weak point in this set up is are the slots into the gear.
Surely 3 lock pins are better than 2 and maybe 4 is even better and engage more frequent
G.B.Shaw
Old 12-04-2008, 09:10 AM
lowslowTJ's Avatar
Member Number: 1051
Good point! the one rear wheel will spin faster than the fronts...right? It also could end in spectacular breakage if for some reason the rear differential did not unlock and the cutting brakes worked well. Pow!
Old 08-30-2009, 01:51 PM
mclark87's Avatar
mclark87 mclark87 is offline
Member Number: 6509
Was this ever revised any to make it stronger or work better? Seen this linked in another thread. Anyone sell anything like this?
Old 08-31-2009, 01:35 PM
SonoranWraith's Avatar
SonoranWraith SonoranWraith is offline
Member Number: 6185
There was a link on page 2 from 635 http://www.der-getriebedoktor.de/shop2/index.htm It is a German site that sells them. Another that sells beautiful planetary reduction axles is http://www.afv-model.com It is only close to $300 euros per axle! LOL
Old 08-31-2009, 09:14 PM
chafey chafey is offline
Member Number: 460
so are there holes in one of the internal diff gears also? or is it just friction?
Old 09-01-2009, 07:07 AM
Rikpal's Avatar
Member Number: 6
There are 4 slot in the internal gear
G.B.Shaw
