Go Back   Scale 4x4 R/C Forums > R/C Manufacturers/Venders/Retailers > Manufacturer/Vender/Retailer
Manufacturer/Vender/Retailer If you would like a forum for your company go here.
Old 08-22-2019, 02:24 AM
Jackson4's Avatar
Jackson4 Jackson4 is offline
Member Number: 28883
Default Etlas NEO II Powerful GCS: High-Integration/10-KM Distance/IP54/4-Hour Battery life
Etlas Neo II is a true warrior that guardians drone's flight mission in spite of harsh weather and environmental conditions. It is yet another big step taken by MMC UAV to expand its product capability for more efficient flight control.It is a new generation of multifunctional and highly integrated ground station that is resistant to water, dust and shock in industrial level. It integrates all the functions of image transmission system, data transmission system, handheld remote, image display system, and industrial laptop.
SPECIFICATIONS
Size(L*W*H) 406*306*93mm
Weight 8kg
Material Aluminum Alloy Plastic
Computer Intel Core i5, 8GB Storage,128GB SSD
Screen Upper screen:15.6-inch LCD /Resolution 1920*1080 Lower screen: 12.1-inch LCD /1500 nit
Battery 4S Lithium Battery
Video Output HDMI
Transmission Distance 8km
Working Temperature -20℃~60℃
Storage Temperature -30℃~70℃
HIGHLIGHTS
Highly Integrated
Traditional ground station system is composed of such devices as image transmission system, data transmission system, handheld remote, image display system, and industrial laptop. This causes many problems like complex power supply, bulky devices, large volume, complex wire connection and difficult debugging. Fortunately, Etlas Neo II has all the functions in itself and is easy to use.
Image and Data Transmission in One
Etlas Neo II is equipped with Photon A10 transmission system that integrates high resolution image link with data control station for bidirectional transmission. The image transmission system can display 1080P images and is compatible with such formats like 1080p60/p50/p30/p25 and 720p60/p50/p30/p25. Photon A10 data control station supports SBUS, serial port and other connectors, allowing for real-time bidirectional data transmission. Image-data integrated transmission spares the problem of frequency interference and incompatibility and simplifies the works of system installation as well as debugging.
Dual Monitor Display
Etlas Neo II adopts dual LCD screens with the upper one showing images and the lower one showing ground station system interface. Its ergonomic design appeals to userís habit. The upper screen is a 15.6-inch ultra-bright LCD screen of industrial grade with an image resolution of 1920*1080. The lower screen is a 1500 nit 12.1-inch LCD screen that is still clearly readable even under the brightest sunlight.
IP54 Ingress Protection
Etlas Neo II is an industrial ground station that is resistant to water, dust and shock and able to work perfectly under difficult working environment such as dust or rainstorm. All the controlling handles, connecting ports, buttons, switches and indicator light are designed to be resistant against water, dust and shock. The corners of its shell are protected by silicone and resistant to shock or fall.
Ten-finger Touch Control
Etlas Neo II is equipped with ultra-sensitive screen that allows for ten-finger touch control and avoids interference caused by accident touch. It is therefore able to work under complex environment with great stability and reliability.
4-Hour Battery Life
Etlas Neo II is embedded with a high-performance battery that can last for 4 hours. It is able to satisfy long-time operation in different scenarios.
Compact and Lightweight
Etlas Neo II measures only 406*306*93mm and weighs only 8kg, which makes it quite portable and convenient for emergent outdoor flying operations.
Strong Compatibility for Extensive Applications
Etlas Neo II has multiple data connector ports which are adaptable with multi-rotor drones, fixed-wing drones, robots, industrial controller and monitoring gimbal, etc.
Super Processing Power
Etlas Neo II adopts low energy consumption industrial motherboard, Core I5 dual-core quad-threading processor, 8G 1600MHz internal storage, 128G hard disk and WIN 10 operating system. It features super strong processing power and high system stability to ensure long-time stable ground station work.
Stereo Speaker
Etlas Neo II is equipped with stereo speaker that can, according to needs ,provide real time voice guide.
Portable Tripod
Etlas Neo II is equipped with a professional portable tripod with quick-release design, height adjustment, and direction adjustment. It is time-saving and convenient to set up the tripod for outdoor operation.
Long Transmission Distance and Low Latency
Etlas Neo II has an 8-kilometer transmission distance and can satisfy most needs for remote control and image display. With a low latency of merely 350 ms, Etlas Neo II could conduct real-time and simultaneous data transmission that makes control signal interact with and respond to flying information, thus improving effectiveness of remote command.
Copyright ©2004 - 2020, Scale 4x4 R/C
