Old 06-16-2019, 01:04 PM
jj650 jj650 is offline
Member Number: 377
Default Killerbody Toyota LC70 on portals
Life got in the way this year and I didn't build anything new for Team KnK hardware's TTC6. Instead I purchased a RTR Redcat Gen8 and did the necessary mods to make it class 0 legal.
I was -8 points short of the -50 scale points going into it but did all I could do.
So needing more scale points and a new hardbody build I decided on the Killerbody LC70. A quick Google search came up with several 1:1 builds on Portal axles. Perfect seeing I need the extra clearance for the tiny tire Dick Cepek 1.9 Fun Country II.
I moved the stock links inward on the chassis holes for the required 12.3" wb.
My plan was to leaf spring the rear but the frame curves inward making me re think that idea. So I made my own cantilever suspension to clean up the rear portion of the frame.
Got rid of all this....
For this.....
Now the body sits down like it should.
Simple aluminum channel bracket on rear. Two knk hardware 3mm SS flat heads bolt the bed down.
Up front I cut the stock inner fenders to clear the body. Again 3mm SS flat heads bolt through the inner fenders into screw posts molded into the body shell.
I had to trim the shock towers for the hood to clear.
That's all that is needed to mount this body to a Gen8 securely. I'll decide on something in the bed to hold a battery so there will be no need to remove the body except maintenance or repairs.
Sent from my Pixel 2 XL using Tapatalk
Old 06-18-2019, 03:09 AM
Member Number: 377
Scale mail yesterday. Yeah!
Because more heavier is better.
Scale awesomeness.
We have coverage.
Old 06-19-2019, 07:03 PM
Member Number: 377
Cut the stock sliders and boxed in underneath to hide esc wires.
Brought the battery plug and switch through cab. Will make a toolbox to house the battery in the bed.
Trimmed and mounted the Axial flares for complete tiny tire coverage.
Old 06-21-2019, 10:10 PM
Noobsk8r Noobsk8r is offline
Member Number: 19523
Too bad that tire wasn’t a slight bit wider to match the fenders but otherwise it looks sweet.
Old 06-23-2019, 06:54 PM
Member Number: 377
Not quite sure what you mean by wider?
Class 0 rules have to have full tire coverage.
These tires are narrow to begin with so I used the 21mm wheels instead of the 24mm.
Thanks.
Old 06-23-2019, 06:55 PM
Member Number: 377
Finally a dry sunny day.
Murder Yota....
Old 07-06-2019, 11:51 AM
Member Number: 377
Color on. And some dirty patina.
Interior and more detailing to come.
Old 07-07-2019, 08:47 AM
Member Number: 377
Tow package and lights installed. Have a headlight out. Lol
Old 07-07-2019, 12:25 PM
Member Number: 377
Battery/tool box done.
Old 07-09-2019, 02:44 PM
Member Number: 377
Primed frame with etching primer and sprayed it with matte black.
Old 07-10-2019, 04:28 PM
Member Number: 377
Today we'll do a lesson in foamanology. Google it....It's not there.
The stock foams in the Fun Country II's... well they suck. They are single stage and very soft.
Hard to see in this pic but they are soft and very squishy. And very unstable on the sidewall.
A browse around Crawler Innovations website brings us to these. The fundicks are 3.85" tall I believe. So their 4.0" and under lil Nova's will do the trick.
Now, the fundicks are a narrow tire. And I mounted them on the narrow (21mm) Boom Racing steel wheels.
So the foam needed modified. I cut the outer foam a tad wider than the tire tread width.
And stuffed that inside.
Next up the directions say if you're running wheel weights you need to use a sanding drum and Dremel to relief the inside of the inner foam so as too not push the outer foam and expand the overall diameter as the foams won't work as designed. Hmmmmm. Never had a problem with it so I did not do that step.
I did however cut off the outer most bead or ridge from the inner foam so it matched the width of the inner bead ring of the wheels. And then stuffed it inside, followed by the weighted inner ring.
What a difference this made. Firm is good.
I gained a little height too which makes the tires look better in the wheel openings.
Before.
After.
This concludes today's lesson.....
Old 07-12-2019, 05:30 AM
foamanology... Add it to urban dictionary, I made up the term junkaneering (to engineer a gadget etc from nothing but the junk you have at hand) and my mate submitted it so it's now immortalised forever
Good results with the wheels too.
Old 07-12-2019, 08:47 AM
junkaneering ,, I like that
Old 07-15-2019, 05:11 AM
Member Number: 377
junkaneering..... Love it! I've been known to use that technique in my builds. lol
Old 07-15-2019, 03:50 PM
Member Number: 377
Interior parts in the mail today. These are pretty awesome seats for the money.
