Old 12-04-2011, 07:51 AM
raw111 raw111 is offline
Lack of Time'r
Member Number: 16118
Default Tamiya Grasshopper rim's to hex?
Hi guy's i was wondering has anyone converted the tamiya grasshopper rims to work on a standard 12mm hex? i would like to use them for a build. or can you recommend a rim that would accept the grasshopper tires? thanks!
would these work?
http://marketplaceadvisor.channeladv...& i=197845456
Old 12-04-2011, 03:20 PM
BADMUTHATrUCKER's Avatar
BADMUTHATrUCKER BADMUTHATrUCKER is offline
Varyag og Muspelheim
Member Number: 1018
B/S/T Feedback: (14)
Nope, they are for fitting Fox/Wild One wheels.
If your application uses normal 5mm axles and dog bones, you could get rere Frog or FAV rear axles and the stock Grasshopper adaptor and swap out the axle itself. The old 3 piece wheels are too thick to drop onto modern axles.
Old 12-04-2011, 09:31 PM
Lack of Time'r
oh thank it wont work at all than thanks!
Old 12-04-2011, 09:39 PM
i have seen the rear and center pieces of the wheel with a hex cut into them and a 12mm hex glued in place to make it pin drive. i have not done it personally though.
i did fit some of the scorcher paddle tires on HPI cup racer wheels though.
Old 12-05-2011, 05:19 AM
Lack of Time'r
Perfect! i was looking ot get the paddle's anything rough about it or did they go on and glue up good?
Old 12-05-2011, 10:22 PM
stewbaru's Avatar
stewbaru stewbaru is offline
Scaler, Trailer, Crawler
Member Number: 12471
Default hex to pin mount - old school tamiyas...
There is a mob in the UK that does them, I can find it if yo need,
Junfac also do a wheel widener that may suit your purpose....
Old 12-06-2011, 06:56 AM
Lack of Time'r
Ya i was hoping to just fit them on not widen. im going to put them on a 1/16 revo i think i am going to go with those hpi cup racer wheel's hopefully the -6 offset will be perfect for what im looking for!
Old 12-06-2011, 07:02 AM
Teacher Brent Teacher Brent is offline
Member Number: 9601
Frog wheel adapters fit perfect. I've used them on hoppers, lunchbox and a traxxas cat. Sorry, I don't have partnumbers.
Old 12-06-2011, 11:40 PM
pantablo's Avatar
pantablo pantablo is offline
Mr. Tire Guy
Member Number: 3012
Those adapters work but add a lot of offset. I tried them once on Brat wheels.
The grasshopper look similar to the Brat wheels [in how they work and attach]. if they are I bet you can get the rears to work, same as on Brat wheels.
*IF* they are the same as Brat wheels you can cut the back and center part to fit a hex in it. not the easiest thing to do but it is very doable. I've done a fair bit of them.
Here's how: http://www.scale4x4rc.org/forums/showthread.php?t=26863
Pablo
Old 12-06-2011, 11:57 PM
pantablo's Avatar
Mr. Tire Guy
Member Number: 3012
I checked my thread and sure enough the stub axle isnt long enough for the wheel+adapter.
http://www.scale4x4rc.org/forums/sho...5&postcount=26
Pablo
