Old 03-08-2012, 07:36 PM
RC John's Avatar
RC John RC John is offline
Drive it like you stole it!
Member Number: 14140
Default SCX10 Dingo driveshaft length?
Hey Guys,
I'm building an SCX10 dingo, and I managed to take all the driveshafts off the parts tree before realizing there are enough parts here to make different length driveshafts. I'm assuming it's so you can change the wheelbase if you had different length links? Would there be a reason to use a different length driveshaft with the links that it comes with?
Old 03-08-2012, 09:07 PM
stewbaru's Avatar
stewbaru stewbaru is offline
Scaler, Trailer, Crawler
Member Number: 12471
Not unless you stretch the wheelbase from 290 - 317mm as per the Honcho body.....
or go for a custom build.
Old 03-09-2012, 05:07 AM
RC John's Avatar
[quote=stewbaru;903132]Not unless you stretch the wheelbase from 290 - 317mm as per the Honcho body.....
or go for a custom build.[/QUOTE
Can you stretch the wheel base without changing the links?
Old 03-09-2012, 08:32 AM
Mirage's Avatar
Mirage Mirage is offline
Member Number: 1152
Another member did the same thing not long ago, he has a picture in his thread showing you exactly which ones to use. Do a search in the 1.9 section and you should find it within the last ~3 weeks.
Old 03-09-2012, 10:57 AM
RC John's Avatar
Thanks!
Old 03-11-2012, 06:47 PM
stewbaru's Avatar
You will need to change the length of something to change the wheelbase.
It will either be the links, the mounting positions or the skid plate.
Old 03-17-2012, 11:16 AM
MojaveMonster's Avatar
MojaveMonster MojaveMonster is offline
a Dezert Speciez
Member Number: 3809
You can stretch it slightly just by adding washers between the link and ball end if needed.
So many projects to finish before Dec 2012.
Old 03-18-2012, 05:46 PM
RC John's Avatar
Nice Tip!
Old 03-18-2012, 05:48 PM
greggreg2011's Avatar
greggreg2011 greggreg2011 is offline
NoM Shelf Queens
Member Number: 16628
also 25.4mm = 1 inch so a simple measure and math will let you know what will fit
