Go Back   Scale 4x4 R/C Forums > Gone But Not Forgotten > KingCobra
KingCobra A Compilation of all Tim's builds
Old 11-17-2007, 08:38 PM
professional amature
Member Number: 136
hehehe... no one even noticed how the front now runs 12mm hex drive wheels instead of fixed axles with bearings in the wheels...
Old 11-17-2007, 08:40 PM
fj40Indy's Avatar
fj40Indy fj40Indy is offline
Newbie level 1
Member Number: 1643
B/S/T Feedback: (13)
Cant wait to see how you do the front suspension. This build looks interesting.
  #18
Old 11-17-2007, 08:41 PM
sloppy's Avatar
sloppy sloppy is offline
Member Number: 863
so what did you do use stampede hubs or make custome ones?
either way good idea.
http://nostr.net/forums/
  #19
Old 11-17-2007, 08:42 PM
fj40Indy's Avatar
Newbie level 1
Member Number: 1643
Wasnt the electric stampede like that?
  #20
Old 11-17-2007, 08:45 PM
Member Number: 136
well I used a set of traxxas steering knuckles... slightly trimmed to fit. worked out very well! and I'm keeping the single control arms on the front for now... if I'm not happy with the performance I'll redo it later and add full independent with long travel arms.
  #21
Old 11-17-2007, 08:48 PM
fj40Indy's Avatar
Newbie level 1
Member Number: 1643
So do you think you will be able to get all the bump steer out of that hornet/grasshopper front end?
  #22
Old 11-18-2007, 06:15 AM
Bigfeet Bigfeet is offline
Member Number: 1213
Thanks for the idea Ive been trying to figure out a way to do the same sort of thing with some traxxas parts. Now I see the light.
  #23
Old 11-18-2007, 02:41 PM
Member Number: 136
this is working out better than planned the rear suspension is all sorted out now and working smoothly. all that remains is shock mounting but I already know how I'll do it. monday the tube frame materials will be here then the fun begins.
  #24
Old 11-18-2007, 04:32 PM
rudukai13's Avatar
rudukai13 rudukai13 is offline
Drain Bamaged
Member Number: 1700
Do you have pics of the droop on it? It's not a prerunner without droop!
I'm and I have a . You had something to say?
  #25
Old 11-18-2007, 05:07 PM
Member Number: 136
here's some droop!
  #26
Old 11-18-2007, 05:08 PM
rudukai13's Avatar
Drain Bamaged
Member Number: 1700
NIIICE
  #27
Old 11-18-2007, 05:12 PM
Member Number: 136
thanks! started modding the body...
  #28
Old 11-18-2007, 05:28 PM
Yeeharacing Yeeharacing is offline
Boca Bearings Team Driver
Member Number: 2566
KC, it looks awesome so far.
What did you make the rear trailing arms from?
If this is the same caliber as your camaro this is gonna be an unbelievable build.
  #29
Old 11-18-2007, 05:33 PM
rudukai13's Avatar
Drain Bamaged
Member Number: 1700
Heck yeah! I can really see this one coming together well! Good luck with it man! You said something about doing some tubing work as well?
  #30
Old 11-18-2007, 05:49 PM
Member Number: 136
the trailing arms are just 1/4 thick aluminum... and it will be coming together much faster after the materials for the tubework gets here tomorrow. yes tubework... a front bumper with light cage, full interior roll cage, rear tubework with spare tire mounts, a roof mounted light cage, and rear bumper.
