Old 11-27-2009, 10:26 PM
crashaholic's Avatar
crashaholic crashaholic is offline
Will crash cars for food!
Member Number: 1217
Originally Posted by scalersince08 View Post
omg this is soo cool. i like the body thing its a good idea. i didnt see how you form them tho do you just pound the - into the +? or what if you could send mr a pm that would be so grate. respect
I mad a few how-to vids, Check them out!
http://www.scale4x4rc.org/forums/showthread.php?t=37582
  #62
Old 12-07-2009, 03:18 AM
Rollmebackover Rollmebackover is offline
OOPS, I think I broke something
Member Number: 4037
Great work! It's nice to see someone build to impress & beat it like you stole it....
Old 12-08-2009, 06:10 PM
highlandcrawler's Avatar
highlandcrawler highlandcrawler is offline
Wishing micros would fly outta my wazoo
Member Number: 3807
This thing is awesome! Defiantly one of my favorite crawlers ever. I am in the process of putting a sway bar on the back of my truck and it will defiantly take inspiration from your setup. What class do you compete in with this thing scale or 2.2 comp
Old 01-13-2010, 08:41 AM
hitman46mod's Avatar
hitman46mod hitman46mod is offline
Member Number: 2432
Holy awesome batman!!!!!
Old 01-13-2010, 06:09 PM
Member Number: 1217
Isn't that the only way?
I run this regular 2.2 comp, I don't consider this a scale truck. It does great as long as i don't need to do any steep climbs but i'm planning on making a new chassis to help with that.
Old 02-05-2010, 10:15 PM
Member Number: 1217
I finally got around to re-designing my old comp truck. Since I can't afford MOA's I needed to make my this one more competitive and since i refuse to be normal I'm sticking with the aluminum body but with a couple refinements.
First off i wanted to lighten the chassis a considerable amount. I couldn't find the aluminum i wanted in time so i went with steel tubing but with only minimal amounts.
I started by using an old AX10 skid plate and making new boat sides that were almost 1/2" narrower than the old ones. They also are now incoporated into the lower links
These new sides also narrowed up the whole body by 1 1/2".
Next i started on the main hoop. this time though, I attached the hoop directly to the boat sides with a plate. i also added the hoop for the rear 1/4's taking about an inch of the back
Then i test fit the old panels
Next i added a lower tube that connected the rear hoop to the skid plate. this also became the mounting points for the upper links and shocks. I also decided to go to a 4 link in the rear while i was at it.
then i made up the rest of the cab taking another 1/2" out of the top.
and finally I completed the front pretty much the same as the rear
and here it is as a rolling chassis with some new shoes
Then i blew it apart and did all the final welding including adding the tabs for the body panels.
you can see how bare minimum the chassis is now and how it ties everything together with out any extra material.
Now here is a comparison to the old chassis
and this shows the weight difference between the old and new chassis.
I shaved off almost 12 ounces!
Now here it fully assembled and running. I threw on the old panels for teasing purposes. I'll have new ones made shortly.
And all the electronics fit snug inside
I really like the stance now and some preliminary testing shows it to be more stable.
Now all i have to do is tear it apart again, tweak the suspension a bit, paint, re-assemble and i'll be ready for Motorama!
0.005" aluminum and shoe goo!!!
Old 01-30-2013, 10:19 AM
Noobsk8r Noobsk8r is offline
Member Number: 19523
I know this thread is old but sweet build and after seeing your skills and watching the vids I think I'm going to try my hand at a k5 with this idea
Old 03-22-2013, 03:16 AM
TeamRawlings TeamRawlings is offline
Member Number: 19677
What a great thread. Really inspired me to give the body panells ago. Found every thing I need at the local hardware!
