Old 01-27-2010, 10:11 PM
MojaveMonster's Avatar
a Dezert Speciez
Member Number: 3809
Originally Posted by Katan View Post
Whoa, sweet chassis
Are you sure those chassis link mounts will hold up?
The uppers are going to be gusseted eventually. The lowers are pretty solid.
For rear shock have some xtm"s off my old x factor and the old savage. I think I had Hotbodies shocks but they make them too long so I replaced the shafts with e-savages which are a little shorter which came out peeerfect. It's the first time I tried it but I turned them down by chucking them into my drill press and put a file to it. Came out pretty nice.
Once the shocks where ready I started on the shock mounts and some tube. Some of the main 1/4" tube accually have 3/16" tube ran inside it for extra strength. Plus the extra thickness helps with the welding. What I really need to do is get some argon hooked up so I can weld the thin wall stuff alittle better
Thanks for watching
Old 01-28-2010, 06:46 AM
Looking good! Where did that steering set-up come from? Is that an aluminum HPI MT rack?
Old 01-28-2010, 09:06 AM
venom*one's Avatar
venom*one venom*one is offline
Member of the C.R.S.P.!!!
Member Number: 1499
very cool truck!!!
Former Owner of BMF#1 BMF Member 21
oh killbucket, your willy is sooooooo big!!!
Old 01-28-2010, 04:05 PM
a Dezert Speciez
Member Number: 3809
Ya, If I remember correctly it is GPM's (something like that ) upgrade part for the MT2. The turnbuckles are New Era and look pretty good but both ends are standard threading so you have to remove one end the do any adjusting.
Old 04-15-2010, 07:09 PM
a Dezert Speciez
Member Number: 3809
Not much to say but here are some updated pics
Old 04-16-2010, 02:25 AM
Katan Katan is offline
Member Number: 558
Looks really good man. Did you strip the axle or paint it? It looks so much better like that, I'm going to have to strip mine now.
Old 04-16-2010, 06:40 AM
Very nice indeed!! Not much needs to be said, the pics say it all
Old 04-16-2010, 10:13 AM
Roady's Avatar
Roady Roady is offline
Member Number: 11162
Wow, I like your Truck, you made a realy good work
Old 04-16-2010, 11:30 AM
a Dezert Speciez
Member Number: 3809
Thanks Guys. Ya, Katan, stripping the axle really makes it pop but when it's all done I'll be trying to get the cage and axle powder coated a steel color. Not sure if you can powdercoat aluminum but that's what I'm shooting for.
Edit: Any Freelance Powder Coaters please pm me. Thanks
Old 04-16-2010, 03:24 PM
SCRT Pilot's Avatar
SCRT Pilot SCRT Pilot is offline
All bad things come to those who haste
Member Number: 10251
You can powdercoat aluminum, I'm sure.
Window profiles for instance are powdercoated or anodized. It will be heated to about 190 degrees Celcius for about 15 min to cure so you have to check whether or not the used type of aluminum will be affected.
Old 04-16-2010, 05:10 PM
rangerboy's Avatar
rangerboy rangerboy is offline
Mud slt!
Member Number: 1264
you can powder coat any metal and very nice work on the rig
Old 04-16-2010, 06:12 PM
Bird8oy's Avatar
Bird8oy Bird8oy is offline
I have a problem and they don't know what to call it...
Member Number: 9312
Your work is great!!! Sharp looking chassis!!
Old 04-17-2010, 02:56 AM
Member Number: 558
I think you will need to get the axle case annodized as powder coating will probably add to much material to the bearing housings etc... Unless you can somehow only get the outside of the case done.
Old 04-23-2010, 05:31 AM
Amazing to say the least!! I cant wait to see a video of this in action!
Old 04-25-2010, 09:13 AM
a Dezert Speciez
Member Number: 3809
Not too much too update on the truck itself other than a failed attemt at a pepper can fuel cell. I did get the body painted yesterday. Really happy with the way it came out....other than the dremil zipping across the pillars giving bothsides a perfect place to brake. Oops.
