Old 05-22-2013, 12:34 PM
ZoZa ZoZa is offline
Member Number: 20114
Old 05-23-2013, 01:02 AM
gall335i's Avatar
gall335i gall335i is offline
truck trial builder
Member Number: 2586
Looking good mate, I see what you mean about the drawings and needing some modifications, started redrawing them on autocad in 1/6 scale so watch for some progress on my thread.
Andy.
Old 05-23-2013, 02:04 PM
I have some laser cutted parts this one between the ladder frame and the backbone tube. They are 3mm stainless steel.
Old 05-23-2013, 02:06 PM
And this one is at the front of the truck, this is the front-shield:
Old 05-26-2013, 12:13 PM
This will be the cover at the front and rear of the central tube. They are made of aluminium:
Old 05-26-2013, 12:15 PM
Laser cutted steel parts for the steering. They are on the steering blocks:
Old 05-28-2013, 03:21 AM
Hanys's Avatar
Hanys Hanys is offline
Member Number: 4723
Default weight
Hi ZoZa,
what is a weight of your descent gearbox? (sestupna prevodovka)
Im looking of your work and it is wery good!
regards Hanys
[email protected]
http://www.rc-trucker.com
http://www.youtube.com/rctruckercom
Old 05-28-2013, 12:53 PM
Hiiii Hanys
First: thanks for the rubbers!
The weight of the completed gearbox (with an uncutted 800mm long driveshaft) is 740g. My gearbox is a little bit wider and longer than the original.
Old 05-28-2013, 02:01 PM
Laser cutted steel steering links. This parts will sitting on the central tube.
They are 6mm steel, and there is 2-2pc 12x6x3mm bearings inside.
Old 05-28-2013, 02:03 PM
With this toothpicks, you can easily imagine how the steering works. I use ball bearings everywhere.
Old 05-28-2013, 02:07 PM
This baby is the steering servo. It can 33kg/cm on 6V and 40kg/cm on 7,2V.
Came from HK. Cheap, heavy, but I hope that have enough power. A serious Tatra builder, Pedrissimo use a servo with a 3:1 gear reducing. His steering has 90kg/cm..
Old 05-28-2013, 02:08 PM
An axial axle for comparison:
Old 05-30-2013, 01:48 AM
Hanys's Avatar
Member Number: 4723
Default Servo
ZoZa:
there is link to my instruction to adjustment servo to BIG power:
http://forum.rctrucktrial.cz/viewtopic.php?f=10&t=1197
Weight is still OK. Tatra made by Michal have all together 18kg:
http://forum.rctrucktrial.cz/viewtopic.php?f=9&t=1073
Old 05-30-2013, 03:45 AM
Louisbaby's Avatar
Whooooosh....
Member Number: 10023
Oh my Gosh... Subscribed
Old 05-30-2013, 11:36 AM
Originally Posted by Hanys View Post
ZoZa:
Thanks for this help.
18Kg.. I think its too heavy, the tire foams can't works with this weight. I'm using alloy and some plastic parts to reducing the weight. And my cab will be made of stirol too.
heavy trucknology
