Go Back   Scale 4x4 R/C Forums > In General > General R/C Banter
General R/C Banter If you have general question that does not fit in the other categories enter it here!
Old 03-04-2020, 01:28 PM
bigdogrod bigdogrod is offline
Member Number: 170
Default what is this? miscellaneous electronics
can anybody tell me what this is? it was just in shrink wrap with no label. it was between the receiver and brushless speed control for a hydraulic pump. left side under my thumb is the servo wires and battery in, the right side is battery out which went to some circuit board that looked like a servo driver, which then went to the speed controller through a standard servo lead. i tried pushing the button, nothing happened.
only thing i can think of is it's a servo channel controlled digital switch. i don't know why i can;t just reconnect the speed controller right to the receiver and set it up on a 3 position switch for off, low, high.
You might be a redneck if, You think the last four words of the National Anthem are "Gentlemen, start your engines"
what!! they're not??
Old 03-04-2020, 03:40 PM
no picture?
Old 03-04-2020, 05:20 PM
chiefsquattingmonkey's Avatar
chiefsquattingmonkey chiefsquattingmonkey is offline
redneck
Member Number: 7866
It's a winch controller. Turns the pump on, forward/reverse, from the transmitter.
Old 03-04-2020, 07:39 PM
Member Number: 170
thanks for the info.
don't know why it won't even light up, so got rid of everything and ran the pump to the receiver. i'll use a rotary knob to control the speed or add mixes in so the pump won't turn on unless the hydro channels are moved
Old 03-22-2020, 12:53 AM
redneck
Member Number: 7866
Nice, excellent way to make it work.
