Old 07-10-2010, 04:25 PM
stevehuckss396's Avatar
stevehuckss396 stevehuckss396 is offline
Member Number: 7455
I made the timing cover today. The cover was cut using the CNC machine then the counterbores were
made manually in the drill press. I now have to chuck it up in the lathe and bore the inside to recieve the
front crank seal. I think the cover will be polished and buffed to a high gloss.
Old 07-11-2010, 08:52 AM
Member Number: 7455
Completed the bell housing adapter plate today. There is a small channel in the back that needs to be milled
for the coolant to transfer between cylinder banks.
Old 07-11-2010, 08:57 AM
lemecanodejante's Avatar
Scale is good!
Member Number: 1144
crazy!!
you "only" done the motor? or you plan to make gearbox, car...
Guillaume
Old 07-11-2010, 09:27 AM
Member Number: 7455
Originally Posted by lemecanodejante View Post
crazy!!
Guillaume
Motor only.
Old 07-19-2010, 06:32 PM
Member Number: 7455
Just a little mini update. I started the intake manifold by getting a block of aluminum to size and cutting the angles on the top edges. Tomorrow I will put the blank in the mill and start carving out the basic shapes on the top side.
Old 07-19-2010, 07:18 PM
oldskoolmini's Avatar
oldskoolmini oldskoolmini is offline
somebody call ghostbusters!!!!!
Member Number: 12168
that is insane!!!!
Old 07-20-2010, 07:45 AM
02edge2wd's Avatar
02edge2wd 02edge2wd is offline
Member Number: 3846
Wow - Amazing work!
Old 07-20-2010, 05:30 PM
Member Number: 7455
Got a call from home today while at work. Starter died on the sons car. Thought I would spend the night replacing that but we set a speed record doing the repair. Had enough time left over to get the top of the intake profiled. Hope to do some more but work is going to stop that for the rest of the week.
Old 07-20-2010, 07:14 PM
caymin last's Avatar
Member Number: 3754
Excellent!
Broke MoFo club member#23,
Old 07-24-2010, 03:48 PM
Member Number: 7455
Getting closer!
Old 07-28-2010, 05:43 PM
Member Number: 7455
Hello All!
Update on the Little Demon. I made some head gaskets today. I took the same approach as the bugatti and made a template. The template was made from 1/8 inch thick aluminum bar 2 inches wide. One drilled and tapped for four 4-40 screws and the other drilled for clearance. The pair are bolted together and machined into the shape needed for the gasket. The long slot is the area under the head that would be impossible to reach with a razor blade.
A slice of teflon sheet is loaded into the template. This piece is a leftover but a smaller piece would be better.
Use a razor blade to clean out the slot and the cylinder holes.
Then use a drill bit to clean out the holes for the head bolts and water jackets.
Remove the teflon from the fixture and install it on the block. Use the razor blade to trim the gaskets outside edges.
And that is all. It took about 5 minutes each after the template is made.
Old 07-28-2010, 07:20 PM
blwn71's Avatar
blwn71 blwn71 is offline
always working on something
Member Number: 1708
thats just freakin awsome dude
Old 07-29-2010, 06:59 AM
Spoon37's Avatar
Spoon37 Spoon37 is offline
Member Number: 16
simple but effective
I like the idea of the templates btw, means you can make a whole lot of spares nice and easy.
Old 07-29-2010, 11:08 PM
chevycrawlerSD's Avatar
chevycrawlerSD chevycrawlerSD is offline
sfrcc
Member Number: 3912
a true work of art
Old 07-30-2010, 04:47 AM
Member Number: 7455
Thanks guys! I plan to do the same thing with the intake gaskets and then I can finish up the intake manifold.
