Old 08-08-2010, 06:07 PM
stevehuckss396's Avatar
stevehuckss396 stevehuckss396 is offline
Member Number: 7455
Originally Posted by FunkyHunk View Post
How much for one engine?
Talk to me after you hit the lottery.
about $1,000 for metal, gears, bearings, springs, screws.
about 800 - 1000 hours at 20 bucks an hour.
$21,000
Conley will sell you one for 6 grand.
  #77
Old 08-08-2010, 07:04 PM
FunkyHunk's Avatar
FunkyHunk FunkyHunk is offline
Without ME, it's just AWESO.
Member Number: 4857
hehe, I'll contact you if I win the lottery then
I was just curious anyways
Originally Posted by 2froo4u View Post
Was are to be happens of things? Tangents snickerdoodles at. Be thus just from do under gallant of have gravy kind doorknobs geese ways twices!
Old 08-08-2010, 10:58 PM
hairba11's Avatar
hairba11 hairba11 is offline
Rollin' in the winnie
Member Number: 4269
Hot Wheels TwinMill
Old 08-08-2010, 11:02 PM
maintguy69's Avatar
maintguy69 maintguy69 is offline
I'm not ignoring you. Your comment is awaiting moderation
Member Number: 8868
yes that would be good, I happen to have that hot wheel
Old 08-13-2010, 02:50 PM
Member Number: 7455
Hello all!
Managed some garage time today. Worked on the bell housing.
Started by machining the OD of the housing and establishing the back of the flange. Then I machined a small boss on the rear so there would be something to hold onto the part when it gets rotated.
I learned this one from watching the members on the HMEM site. I machined steps every .025 to the proper depth to form a .500 radius.
Then with a file and some sand paper, the steps were blended together to form the curve.
The part was then rotated and the flange was brought to size.
The inside was drilled thru and the two bores were made.
The insite corner was knocked down on a 45 degree angle to complete the inside shape.
A small step was them made to give the proper size to fit the boss on the rear plate.
Again the part was rotated and the holding boss was removed and cleaned up a little.
I still need to drill the hole pattern to mount the piece but that should be a quick deal!
Old 08-13-2010, 04:35 PM
caprinut's Avatar
caprinut caprinut is offline
Member Number: 448
Holy .......
Awesomeness indeed
R.I.P Ole (8th Oct 2012)
Old 08-13-2010, 08:13 PM
maintguy69's Avatar
Member Number: 8868
yea really just keeps getting better and better
like how did the radius, beats having special tooling
Old 08-13-2010, 08:29 PM
Member Number: 7455
Thanks!
Funny thing is, I have the special tooling. I'm just to lazy to switch the tooling back and fourth.
Old 08-14-2010, 05:44 AM
I love this, but one thing's bothering me: So far you've got a near-perfect replica of a Chevy small-block, why the Ford valve covers? Especially when 4-bolt Chevy's would be easier to make?
Old 08-14-2010, 10:29 AM
Member Number: 7455
Thats because they are chevy big block covers. I copied a set of BBC covers I found a picture of on the web somewhere.
Nothing I do is about being easy!! Hahaa!
Old 08-15-2010, 01:41 PM
Member Number: 7455
Hello All!
Had the chance to make some cylinder liners today. Having so many to make, I decided to predrill the centers so it won't have to be done on the lathe.
I make my liners with 3 diameters to make the liners easier to press in. The problem with that is, it makes it easier to screw up and have to scrap a piece with one more diameter to have to hit.
I turn the liner ID to .015 - .020 smaller than finished size. I like to press them in the block and binish the bore installed.
I part the liners off long so the deck of the block can be milled to match the liners. Then the part is rotated and a skim cut is taken to smooth the surface for pressing.
With the 3 step liner and the bore to match, the liner drops in more than half way making it easier to push in. I use a Q-tip to paint on some green loc-tite and send them home.
One down, one to go.
Old 08-15-2010, 01:48 PM
And now I see how you did the water jackets, too. I was wondering about that.
Old 08-15-2010, 02:52 PM
Member Number: 7455
Not very difficult to do water jackets.
Old 08-21-2010, 02:57 PM
Member Number: 7455
Hello All!
Found some garage time so i sprang into action. Setup the block and indicated it in.
Took a cut across the deck surface to get the liners down to the deck height.
Then I ran a boring bar thru the cylinders to bring the holes to size. and called that done.
Then I made the 32 lifter bushings for both blocks.
Tomorrow the other block will get finished.
Old 08-21-2010, 04:25 PM
maintguy69's Avatar
Member Number: 8868
allmost to the same stage as the Bugatti, so time for new project ?
