Old 11-20-2019, 05:51 PM
Default Bantam T3-C
I'm in the process of building a trailer to go with my CJ-6. It started as a Hasbro GI Joe Bantam T3. After doing a little research, I decided to make it the civilian version, the T3-C. I got some wheels and tires from a stock Willys Jeep, and painted them up. I made an axle and fabricated it so each wheel spins independently on bearings, that way there isn't any binding while turning. Waiting on some cut-off wheels that I ordered, so I can get the tongue pieces cut. I'm still not sure how I'm going fab up the drawbar/lunette mount.
So here's a couple of pics of the progress so far...
Old 11-24-2019, 08:31 AM
More progress today...shackle/spring mounts fabbed and mounted, tongue support bars cut and installed, and shocks mounted. Trying to use as much scale hex hardware as possible, but I will need to order some more. Just have to use button heads for now.
On to the pics...
Old 11-24-2019, 09:28 AM
looking really good!
Old 11-25-2019, 05:55 AM
Thanks heartless. I'm hoping for more progress on your Ford pickup.
Old 11-25-2019, 05:59 AM
yeah, i was hoping to have more progress as well, but have been crazy busy with real life.
maybe over the upcoming 4 day holiday weekend I can get a little time in on it.
Old 12-01-2019, 06:04 PM
Had a few days off for the holiday and made some more progress. Fabbed the stanchion mount out of styrene. This a little too intricate to fab out of brass or aluminum. Maybe it could be 3D printed in aluminum.... Although this is small, it took me 2 days to build it. It's fully functional and scale, at this point.
This is what I wanted to replicate
I still need to fab the coupler to fit a scale, 2 inch ball, but here's what I have so far...
Old 12-01-2019, 10:21 PM
stomperxj's Avatar
stomperxj stomperxj is offline
Small Crawlin
Member Number: 236
Nice work. I just picked one of these up for my 1/6 willys project
Check out my trailer build: SawTooth XL Off Road Trailer
Visit my site: http://www.sawtoothent.com
Old 12-02-2019, 10:28 AM
Excellent! There are a few of those running around. You can make it functional with the Willys quite easily. Check out post #3 here... http://www.rccrawler.com/forum/large...ml#post5980635 Mike Flea has a good pic of a simple lunette hook up. There's also a bunch of Willys builds that you can find good info on building yours.
I still have the Hasbro Jeep that came with this. I bought the set just to get the trailer, for $35. I figured, that's a reasonable price for a trailer, considering the newer Jeeps are pulling at least $100. So, if any body is listening, I'm giving away my 1/6 Hasbro Willys for the cost of a trip your house. It has no windshield and the headlights were pulled for mock-up, but I still have them somewhere, that I will include.
Have you started a build thread for it yet stomperx? I like to watch.
Old 03-21-2020, 08:42 PM
Well, being home with everything that's going on right now, I actually got motivated to finish the frame.
Created the hitch that is functional on an 8mm ball, which is about scale for a 2" ball. Each wheel rotates individually which minimizes any potential binding while turning. I will try to get the bed primed tomorrow, for now, some pics...enjoy.
