Old 03-13-2013, 10:01 PM
Jugg2Driver's Avatar
Member Number: 3
Here is construction of the roll cage and bumper installation.
Old 03-15-2013, 11:35 PM
Member Number: 3
Wheels, tires, rear tire carrier, and complete roller!
One of the nice features here is the wheel hex that is held on by a grub screw.
Old 03-15-2013, 11:36 PM
Member Number: 3
obligatory articulation shot!
Old 03-18-2013, 11:39 PM
Member Number: 3
Now it is time for the body work.
first pics are the lights and light buckets, held on with double sided tape.
Old 03-18-2013, 11:42 PM
Member Number: 3
This next set of pictures shows how the body looks sitting on the chassis and then how the roll cage is mounted and how the side mirrors are installed. Note that on things like the side mirrors that you have to drill the holes for them to mount and there is no indication as to where that is on the body. This actually true with all of the mountings, the body posts and roll cage are not pre-marked with indentations like some bodies are.
Old 03-18-2013, 11:45 PM
Member Number: 3
Now the really fun part! Mounting the fenders. Again, as with the mirrors, there is marking on the body for where to drill holes, the best I did was to use the interior mounting bracket as a guide to mark the approximate locations of the holes.
Old 03-18-2013, 11:48 PM
Member Number: 3
Now for pics of the nearly completed body and the mounting of the hard top. What I did to mark the screw locations for the hard top was to paint the mounts (on the roll cage) with silver paint and then set the top in place and press down so that the paint would mark the inside of the top.
Another way to avoid this is to set the body up for mounting and all installations before painting so that you can mark the outside where the protective film is; that would solve some of my issues....but
Old 04-02-2013, 10:22 AM
FunkyHunk's Avatar
FunkyHunk FunkyHunk is offline
Without ME, it's just AWESO.
Member Number: 4857
It looks like a quality axial product once more
But, one would think they'd make a little bit more scale axle housing?
It's almost four years (i think) since the first axial with that design?
Originally Posted by 2froo4u View Post
Was are to be happens of things? Tangents snickerdoodles at. Be thus just from do under gallant of have gravy kind doorknobs geese ways twices!
Old 04-02-2013, 01:29 PM
THE_JOKER
Posts: n/a
Member Number:
Seen them Vanquish Currie jobbies for it?
Nice kit! going to get myself one tommorow me thinks and re-enter the hobby.
Old 04-03-2013, 06:12 AM
Originally Posted by Jugg2Driver View Post
Note... the body posts and roll cage are not pre-marked with indentations like some bodies are.
That's very odd. You'd think that would be built in like most of the Axial bodies. Has to be a pita.
Old 04-03-2013, 06:26 AM
But it also means you can use the body on other projects, without having indents for holes you're not going to drill
Old 04-04-2013, 09:50 AM
THE_JOKER
Posts: n/a
Member Number:
Mine came today though I ended up going for the RTR one instead. Anyone know why only the kit version has the roof with it? I'm most likely missing an obvious point.
Old 04-05-2013, 03:08 PM
Member Number: 3
It is a PITA if you paint the body before you line up all the mounts as I did. Had I paid more attention I would have drilled all my holes prior to painting.
Old 04-05-2013, 03:09 PM
Member Number: 3
Probably just another way of differentiating the two from each other. I think the RTR has different wheels.
Old 04-05-2013, 11:33 PM
OllllO Fanatic OllllO Fanatic is offline
Member Number: 18412
what light buckets are you using?
