Old 09-18-2019, 12:32 PM
Got the red stripe painted and have started test printing some decals.
  #137
Old 09-19-2019, 12:04 AM
That water tank is pretty awesome, i wonder if the lid could use stock from an O-ring repair kit or silicone rod, or fuel tubing for a gasket.
For your vent line, i might come straight up with it, then zigzag many many cm back and forth above the tank so that it won't spill easily when picked up wrong
I do not know Norway ARFF at all. I also didn't go back to look at your prototype pics.
I'm actually not all about that red stripe as it sits, it feels like it'd look more finished if 2nd door leading edge of stripe were raised so it's in line with the front and rear stripes. Maybe go even more height change with connector segment so its more of a Z or N type line. Ideally i'd suggest the cab get a solid line section.
The rest of the decals are looking good. I might size 'Royal Norwegian Air Force' up to height of the small panel its on. I also might shove the large 3 aft, and put the airport identifier code forward of that. Example my airport would make it something like 'IND 3' or 'KIND 3', although i think my real ones have the full 'Indianapolis International Airport' billboards.
It looks great, and i am in no way trying to bash any of it.
Old 09-19-2019, 05:43 PM
Thank you for your thorough constructive criticism. I've been staring at reference images for 3 years and have become quite fond of this design, so it's refreshing to hear from a different perspective. You bring up some interesting points, and I greatly appreciate your input.
First, here's the real thing. My test prints are pretty close to accurate at the moment.
4x4:
6x6:
http://www.egenes.as/news.asp?id=9713&c=178&t=451
I can't speak for the designer of this livery, but I have some thoughts about how it came to be.
Stripe
The standard Scania cab has a wide indented line (there's probably a better word for it) that starts at the front corner, cuts across the door panel and ends just in front of the rear corner. When they make the crew cab, they split the cab and insert an additional door, leaving the line broken. The rear door is also a tiny bit higher up than the front one, which means the two line segments aren't quite equal.
Most Scania fire truck designs seem to fill these indentations with a contrasting color, so I'm very used to seeing them that way, and to me it makes sense to use the body features and curves when designing the livery (my favorite example of this is the Gulf McLaren F1 race car). There are however a few that pull a straight line across the side.
http://www.egenes.as/news.asp?id=14499&c=167&t=425
http://www.egenes-brannteknikk.no/ne...4&c=167&t=425#
Personally I feel that looks a bit messy on Scanias in particular, like coloring outside the lines, so keeping them away from the design seems like a better option in that case. The British emergency vehicles love to dress up in large squares (Battenburg markings) which to me looks better than a straight line.
http://www.fire-engine-photos.com/picture/number38342
Avinor, the agency owning and operating most civilian airports in Norway, also have a fleet of similar Scanias, but they went with a simpler design incorporating the area around the door handle instead.
http://www.rosenbauer.no/news.asp?id=13363&c=178&t=451
It's worth noting here that the Tamiya body isn't perfectly proportioned in this area. The door handles and indented lines are a bit too high up on the doors. I think it looks more balanced on the real trucks than on this model.
Text
From my trips to google image search, I'd make the claim that air force ARFFs often stick to a basic design, with a large number and maybe a "United States Air Force" or "Royal Air Force" text, without identifying their home base. I assume this helps if you have to move equipment around. Keep the cost low, just basic information. Rip off the number and slap on a new one and ship it somewhere else. I feel these Norwegian trucks fit into that pattern.
I agree the RNoAF text would fit better if it was larger (and I'm considering sizing it up a bit to make it easier to cut), but it looks like they used the same stickers for the 4x4 and 6x6 trucks, so I assume the space on the tank of the 4x4 version is the limiting factor.
Belgian air component Panther 6x6:
USAF:
RAF example:
And I absolutely love this from Finland:
Even though most of the RNoAF and Avinor ARFFs don't feature an airport identifier, the largest commercial airports have their own fleets of Rosenbauer Panthers with airport logos.
I also want to throw an honorary mention to this Scania living in Antarctica on the Troll base.
https://www.scania.com/group/en/a-fi...in-antarctica/
About the water tank: Doing a zig zag thing on top is a great idea! The tank ended up a few millimeters too tall, so I'm struggling to fit anything on top, but I'll see if I can use that idea somehow.
Old 09-19-2019, 08:13 PM
Thank you. Please disregard 80% of the previous post. I'm not up on military arff at all. I'm used to Oshkosh that don't really have to worry about getting reassigned to other airports until retired.
http://www.indianafiretrucks.com/Sta...?StationId=624
http://www.indianafiretrucks.com/Sta...?StationId=625
Your livery is looking almost spot on to the real one!
On the real 6x6 truck, is the hookup between roller door and first rear axle for loading water into the tank or draining?
Old 09-19-2019, 08:54 PM
As I mentioned, I'm making a lot of assumptions, and may be completely wrong about all of them.
About the hookup, I'm not sure. I've always assumed it was for loading, but I don't think I have any photos of it in use. I should add that to my list of questions.
https://www.scania.com/group/en/wp-c...l-720x480.jpeg This photo suggests that the hookup for filling with the internal pump is behind the roller door, so the exposed one might be for direct access to the tank to fill it with external water pressure?
Old 10-01-2019, 09:33 PM
Chest for the roof. Started by making a small table out of 2mm styrene, then wrapped it in Plastruct styrene tread plate. It doesn't open, but it's hollow so it can slide over the water tubing sticking out of the roof.
Started making the ladder. I was going to use precut strips for the sides and rod for the steps until I realised the total length of just the steps are more than 6 feet. Now I'm cutting strips out of 1mm styrene instead. The sides are 1x4x300mm + 2 pieces 1x2x300mm. Steps are 2 pieces of 1x3mm in 30, 36, 41, 36 mm lengths. Ladder itself is 3 elements and it rests on another element that is mounted to the roof and slides+tilts down to ground level.
Old 10-12-2019, 06:47 PM
Thank you!
Ladder progress. I'm not sure how the pulley system works on the real one, so I don't know if I'll make it functional or just glue everything together.
I think I finally found the perfect water tubing for the monitor. 3mm ID, 5mm OD, 1mm wall thickness black silicone tubing. I tried 0.5mm wall thickness too, but that was way too thin and would kink at almost any bend radius. This one doesn't kink but is still very flexible and won't stress the servos.
Old Yesterday, 02:25 PM
Finally found the name and enough reference material to figure out how the ladder works.
It's a Wibe Nor-Bas ladder.
http://www.wibeladders.no/globalasse...parts-list.pdf
Old Yesterday, 07:42 PM
Got started on the pulley system. Still not sure if it will actually work, as there will probably be too much friction in those tiny pieces. And I'm 99% certain that the rope actually passes through one of the steps to go from the right to the left side at one point, so I might have to simplify that.
It's also one of those fun situations again where I can't paint it until it's finished, but I can't disassemble it to paint it after it's done because of interlocking pieces.
