Old 01-23-2020, 01:13 PM
bigdogrod bigdogrod is offline
Member Number: 170
Default monster truck tire with different inside diameters
just picked up a set of risky concepts 2.6 rims, and i notice the back side has a larger diameter than the front. what tires fit these things? i've seen this in smaller sizes (tlt right?), but not for clod
You might be a redneck if, You think the last four words of the National Anthem are "Gentlemen, start your engines"
what!! they're not??
Old 01-24-2020, 06:05 AM
Thorsteenster's Avatar
The 4rd prize winner!
Member Number: 990
Are these the wheels?
https://www.ebay.ie/itm/152521110223
Edit: You may have to copy and paste url to work, when I click it goes to page not found on Ebay.com
If you click Full Description it says it's a "Hybrid" wheel, 2.6" outer and 3.2 inner for knuckle clearance, and that it "fits" Clod and USA1 tires.
http://vi.vipr.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=152521110223&t=0 &tid=10&category=182201&seller=usa-selling&excSoj=1&excTrk=1&lsite=0&ittenable=false& domain=ebay.ie&descgauge=1&cspheader=1&oneClk=2&se cureDesc=0
I guess they expect you to cut the inner tire bead? Beats me, other than TLT tires and newer short course/Slash I haven't seen any such tires with smaller outer bead.
R.I.P. www.varcoffroaders.com
Old 01-24-2020, 07:02 AM
Member Number: 170
those are the ones. i can't find riskey concepts anymore except on some old youtube videos. i got a clod tire stretched over the rim, but they need air holes and foam.
problem now is they won't clear the links on my blackwell axles, so i need to find a 17mm to 17mm widener
