Old 05-17-2015, 12:13 PM
4x4lover4499's Avatar
4x4lover4499 4x4lover4499 is offline
To many projects not enough time.
Member Number: 16060
I did it, leafed rear suspension!
And I lost about a 1\4" of flex total, not enough to worry about for sure. Rear tire is off the ground.
When in doubt, Throttle out!
  #92
Old 05-18-2015, 01:29 AM
350TacoZilla's Avatar
Member Number: 2402
looks great man, if the springs are new you might get that flex back after few runs.
Old 05-18-2015, 08:59 PM
Thanks, kinda what I am hoping for. They are not new, but I really don't think they have much use.
Old 05-19-2015, 06:13 PM
Member Number: 2402
One thing that I cant tell for sure in your pic of the naked chassis, is the shackle straight up and down sitting with the weight of the truck on it? On most leaf setups its best to have just a bit of angle to them so they can flex both directions if looking at the truck from driver side the shackle should angle bit like this \ if yours is straight up and down that might gain you tiny bit of flex by just moving you upper bolt hole forward a bit.
Old 05-19-2015, 07:01 PM
Yeah the shackles are vertical. Misjudged the hole by 1\8" I plan on correcting the mounting and installing some 70 mm shocks in the morning. Might have to make some slightly longer shackles to correct my pinion angle.
Old 05-20-2015, 07:08 PM
A little taste of the mud
http://vid1263.photobucket.com/album...psnbmaa0fl.mp4
I picked up my second body, now considering a 2.2, TTC F650
Old 05-27-2015, 12:17 AM
Well the leafs kicked my but, I want to go for a trail ride tomorrow so I threw the 4link back on.
I put my wife's rig back together, traxxas big bores in the rear and strc aluminum hoops.
Old 05-27-2015, 03:58 PM
Put a new grill in this morning.
Old 06-16-2015, 08:20 AM
redneck thug redneck thug is offline
Member Number: 21300
great lookin truck there....
Old 08-27-2015, 05:52 PM
Thanks, still working on it...
Decided to do a bit of modifying, took the wood bed off and mocked up the new camper?
Old 08-28-2015, 05:18 PM
Old 08-29-2015, 04:40 PM
Trimmed the camper down 1inch and glued her together.
Old 08-30-2015, 07:32 PM
Interior started.
Old 08-31-2015, 08:57 PM
The rest of the interior.
Window view.
Door view
Old 09-04-2015, 01:58 PM
