Go Back   Scale 4x4 R/C Forums > Monsters, Scale 4X2, & Non scale R/C > Tips, Tricks, FAQ's
Tips, Tricks, FAQ's Questions about the monsters? Ask them here! Got a great "How to" post it here!
Old 10-13-2009, 03:04 AM
BIGBIRD's Avatar
BIGBIRD BIGBIRD is offline
redneck road trip
Member Number: 5987
Default rooster crawler with 19 turn? but low geared.
here is my question, i have an rc4wd 2 speed tranny, and a 2-1 transfer case running my rooster with 55turn, and it is way to slow. is it a bad i dea to run my 19t motor if the gearing is really low. is it heat i need to worry about. or do i just forget it and just up the pinion? full throttle right now is just faster than walking pace. running 7.4 lipo.
i am running it in my scaler, that weighs over 10 lbs. not a comp style crawler.
Old 10-13-2009, 10:59 PM
Arcocustom's Avatar
Arcocustom Arcocustom is offline
Three .001 on every moving part.
Member Number: 2344
Don't go lower than 27 turns. Adjust your gearing so the ESC and engine are the same temp. after a run. That = efficiency.
Old 10-14-2009, 04:35 PM
rs speed's Avatar
rs speed rs speed is offline
Got scale?
Member Number: 5348
B/S/T Feedback: (8)
I run a 17t with a 7:1 gear reduction and it feels great but I'm using an FXR. its for my 1:6 scale f150, well over 10lbs.
http://rspistons.com/images/rcsig.jpg
Old 10-14-2009, 04:42 PM
talon talon is offline
Banned
Member Number: 3176
just bump up the tooth count on your pinion 2 or 3 teeth and see how warm things get.
Old 10-14-2009, 04:44 PM
I wouldn't recommend it, but you could probably get away with it. The 19 is going to draw much more power than a 55, so watch it.
Old 10-14-2009, 04:46 PM
Banned
Member Number: 3176
and with so much higher RPM's you will lose alot of efficiency, and gain alot more heat by using the 19turn. your risking at the minimum smoking the motor, if not the esc if you bind it up. but you will most definitely lose ALOT of run time.
Old 10-26-2009, 08:20 PM
warnoffroad's Avatar
warnoffroad warnoffroad is offline
TUG-O-WAR Lord.
Member Number: 403
I run a 19t motor with a Rooster Crawler ESC in an R2D 2 speed in a scaler. Nothings burnt up yet, but when the rig get a nice size load the ESC does stall out. The R2 wont last long with the wheelspeed of a 19t though, I would suggest a 35t lathe. Its got gobs more wheel speed then a 55turn, you wont lose too much torque either.
Im actually a 75%er that's just giving you an extra 20%
Old 01-11-2010, 08:55 AM
ser3100 ser3100 is offline
Member Number: 9765
I had the same type question so now i got the answer. I was gonna run a Reedy challenger 19t in my sons Honcho but that motor get way too hot running in a Slash so ill just wait for either a 35 or 45t.
