Old 05-01-2019, 05:40 AM
Thread Killer's Avatar
Thread Killer Thread Killer is offline
Learning to Crawl
Member Number: 28428
Default John Deere Scheme Bruiser Clone with Mods
New here. Just wanted to share what I did with this truck to improve looks and performance. I had this idea:
Mods:
Paint
2.2 A/T Tires
RC4WD 45t motor
Front winch bumper
Rear tow bumper
Electric winch
Marlin Crawler roll bar
LED light bar
Gas can
Fire extinguisher
RC4WD Scale shock boots
Driver
Rear window with louver
Antenna
Light kit
New steering servo, arm and ball joints (a lot less slop)
Tow chains (came with my outdoor grill)
Beadlock rings. I used linoleum nails for the rivets. Attached to stock rims for now. Eventually would like to get nicer wheels but this rig doesn't use the 12mm set-up.
Thanks for checking it out, Brian.
Old 05-01-2019, 01:24 PM
Looks awesome, like the paint scheme. wheels came out great!.
Mark
Old 05-02-2019, 05:04 AM
Learning to Crawl
Mark
Thanks Mark.
Beadlocks aren't really beadlocks though. Looks a little funky. Anyone have any experience using 12mm mount wheels on one of these? I've seen adapters but it looks like they cause a lot wider stance. Thanks.
Old 05-02-2019, 09:19 AM
this is mine
I am using the rc4wd bruiser wheel adapters
https://store.rc4wd.com/12mm-Hex-con...12_p_2504.html
the inner end of the rear shafts need to be filed to have flats to fit the clones diff
Old 05-02-2019, 09:38 AM
Learning to Crawl
Yes Walter, that's more like it. I would buy that kit today but its been on B/O seems like forever. Did a search online and most all out of stock except for one or two foreign stores. B-
Old 05-02-2019, 11:16 AM
You could also try these? I like to think Paul drew inspiration from my hubs?lol. Was emailing quite a bit at the time while installing some rcchannel parts on my Bruiser build. Who knows?... Anyway, great idea lol.http://www.rcchannel.com.tw/product_info.uphp?cPath=25&products_id=384
Nice Mounty Walter!
Old 05-02-2019, 02:36 PM
Learning to Crawl
Thanks Mark, only thing is that you are limited to their 2.2 aluminum wheels only. Plus I couldnít even find them on their website. I have some in mind right now. Iíll post a picture when Iíve installed them.
Old 05-02-2019, 03:53 PM
No problem... BTW I think in the description when it refers to being for 2.2's -It actually means "their" 2.2's as opposed to "their" 1.9's. Rc Channel 1.9's are mounted with 5 holes, while their 2.2 size wheel is 6 hole mounted. I'm 99% sure, to use 1:1 terminology, that the "centers" (radius of hole pattern as in "from center") don't change. In fact are the same as rc4wd 1.9' wheels et al... However it sounds like it may be a moot point as you are going a different route anyway.. looking forward to your updates, Mark.
Old 05-02-2019, 07:12 PM
Learning to Crawl
Wink
Too bad Tamiya didnít get the memo about the 12 mm idea. Itís all good though, part of the fun trying to figure it out.
Old 05-02-2019, 07:58 PM
Learning to Crawl
By the way Mark, I did look through your Build thread with the quad shocks and the steering stabilizer and all that good stuff. I would poke my eyes with toothpicks before attempting any of that stuff, LOL
Old 05-02-2019, 10:15 PM
Lol, I still might!?
Old 05-06-2019, 07:37 AM
Learning to Crawl
I got a set of these machined wheels, 2.2 x 1.5 wide. They came with 4 14mm long offsets with a 12mm hex on each end. I was able to modify these and use them as adapters. They have a set screw on one end so all I did was cut the other hex off and lock it onto the shaft. As luck would have it, they fit perfectly on the shaft. Now I can use any wheel with a 12mm hex.
Old 05-06-2019, 01:57 PM
[email protected] great thinking on the wheels. Now you have s proper set of beadlocks all custom mounted... The more I see of the hg 407's, the more I want one
Old 11-29-2019, 05:59 PM
big specht big specht is offline
Member Number: 11037
Has any body found any wheel adapters for these trucks that don’t make them to wide?
Old 12-01-2019, 12:35 PM
4x4lover4499's Avatar
4x4lover4499 4x4lover4499 is offline
To many projects not enough time.
Member Number: 16060
Here you go ..... Start reading......
https://www.scale4x4rc.org/forums/sh...ad.php?t=28745
When in doubt, Throttle out!
