Old 10-30-2012, 11:45 AM
brel's Avatar
brel brel is offline
tank nut
Member Number: 13479
thanks mate
Old 05-16-2013, 02:53 AM
brel's Avatar
tank nut
I have replaced the Futaba S3003 standard steering servo with a Futaba S3305 servo because this one has a higher torque rating than the standard servo and it improves the steering on carpet, the S3003 servo struggled on carpet to give full lock, I am also reworking the wiring inside the truck to get rid of the "Birds nest", also replacing the on/off speed controller with an ESC to give better control on the forks elevation/lowering
before the alterations to the wiring under the cab
after the alterations, the two black connectors on the left connect to the two ESC's , the white one in the middle connects to the orange flashing beacon and the black one on the right is the main battery connection
this is the replacement ESC
I have replaced the head lights and re-wired them to tidy up the wires in the truck, also going to shorten the servo leads to the tilt and steering servo and to the ESC's as well
Old 05-16-2013, 12:53 PM
brel's Avatar
tank nut
got the new ESC installed for the forks lift/lower
also made some new cylinders for the rams on the top of the mast that tilt the mast on the 1:1 truck
this is because the original ones supplied with the truck are too short and the ram drops out of the cylinder
fully tilted back
rams in the new cylinders at full tilt forwards and full back tilt
Old 05-29-2013, 02:16 AM
brel's Avatar
tank nut
added afire extinguisher to the FLT
Old 05-29-2013, 11:30 PM
brel's Avatar
tank nut
you tube link of the FLT loading my flat bed trailer built from a tamiya reefer chassis and running gear
Old 11-12-2013, 08:20 AM
brel's Avatar
tank nut
I have added a pair of extra headlights to the front of the cab using some brass tube and two 3mm white LED's and a resistor to reduce the voltage
spaghetti wiring LOL
truck re-assembled with the new lights
Old 12-10-2013, 09:18 AM
brel's Avatar
tank nut
I am getting a HeyOk lighting controllers that RC4WD are now selling.
decided not to use this as I changed the Esc for a servonaut one
Old 12-26-2013, 06:18 AM
brel's Avatar
tank nut
A short video showing the newly installed reversing light in the LH rear light cluster
using the brake/reverse light controller
photbucke tlink broken
Old 12-05-2016, 09:51 AM
brel's Avatar
tank nut
Decided to update the electronics in the FLT and fitted a Servonaut S22 ESC and a Servonaut MFX for the lift motor. The S22 has outputs for brake and reversing lights, which have also been fitted using 3mm LEDs and resistors
It has only taken me 5 years to fit the reversing and brake lights :O :O :haha: :haha:
Old 12-05-2016, 11:22 AM
smokinscott1977 smokinscott1977 is offline
Member Number: 10390
For the figures all action figures in the 3.75" category seam to fit and work ok and for the most part are posable i think bruder has a line of people in their bworld line hope this helps
Old 12-06-2016, 09:32 AM
brel's Avatar
tank nut
Originally Posted by smokinscott1977 View Post
For the figures all action figures in the 3.75" category seam to fit and work ok and for the most part are possible i think bruder has a line of people in their bworld line hope this helps
thanks I will bear this information in mind when I get a new driver for the truck
Old 07-11-2017, 10:16 AM
brel's Avatar
tank nut
bloddy photobucket are shite
never mind I found a new picture site and here are a few of the FLT
Old 07-11-2017, 08:12 PM
Nice to see the forklift again.
Old 07-12-2017, 06:12 AM
brel's Avatar
tank nut
Originally Posted by nickvb1996 View Post
awesome all we need know is a video
here ya go, a video of the FLT unloading my flatbed semi trailer, bulit using the chassis of the tamiya reefer
sorry but my Youtube was hacked so I lost the video
Old 03-21-2020, 06:37 AM
brel's Avatar
tank nut
truck pictured on facebook with the hand made pallets
https://scontent.flhr3-1.fna.fbcdn.n... &oe=5E9B818F
https://scontent.flhr3-2.fna.fbcdn.n... &oe=5E9CBE5E
