Go Back   Scale 4x4 R/C Forums > Scale 4x4 R/C Trux! > Tips, Tricks, FAQs > Styrene Extreme
Styrene Extreme Tips and tricks and working with sheet styrene for those ultimate custom builds!
Old 01-30-2014, 04:48 PM
DieselRC's Avatar
DieselRC DieselRC is offline
Diesel Fanboy
Member Number: 21099
Default Bending or molding styrene?
Hey guys just wondering what y'all do to bend or mold your styrene. i have .040 and .060 and i would like to make wheel wells. Any ideas on how to shape it? Perhaps heat?
Old 01-30-2014, 04:53 PM
MrRcFanatik's Avatar
MrRcFanatik MrRcFanatik is offline
R/C and Subaru nut!
Member Number: 21111
I've used a heat gun or butane torch (ON LOW!!) to bend it man. Usually a good idea to make up a piece of wood to help you get the right bend though... free hand usually doesn't work out well.
I've also seen others (in specific JosB on here) take a length of styrene, and tape it onto a wooden or glass form, and then put the whole thing in an oven on low for a while. When you remove the tape, the styrene will stay in the curved shape.
There are most likely way more ways you can do it, but yes, heat will be your ticket here!
Old 01-30-2014, 06:28 PM
DieselRC's Avatar
Diesel Fanboy
Cool thanks for the reply
Old 01-30-2014, 07:38 PM
sickcivic95's Avatar
sickcivic95 sickcivic95 is offline
Lost and confused on.... what was I saying?
Member Number: 6114
B/S/T Feedback: (29)
Another option is boiling water, you can wrap the styrene around an object of the shape and dip the entire thing in boiling water for a few minutes to mold it. I've done this a few times with good results.
A heat gun works but on LOW heat as high deforms it while molding it.
--Dan
You can't keep a good douche bag down It's a douche world, we're all bagging in it- Quoted from thorsteenster
Old 01-30-2014, 07:40 PM
pfitchie's Avatar
pfitchie pfitchie is offline
Member Number: 19206
Yup! Ditto on the boiling water.
Old 01-30-2014, 08:19 PM
imthatguy's Avatar
imthatguy imthatguy is offline
Styrene Dust
Member Number: 12146
B/S/T Feedback: (10)
Steam works a treat as well. Easier to manage than boiling water. And slightly more portable.
SBG YOUTUBE AXIAL AMBASSADOR GCM TEAM DRIVER VANQUISH KNIGHT CUSTOMS TEAM
Old 01-30-2014, 09:05 PM
Member Number: 6114
Steam does work great I've used a vaporizer before...lol it takes awhile bit it worked...I've even heard of people using steaming irons before bit never tried it myself.
I use an old parabolic heater by my workbench to warm the styrene before molding it. It works great and seeing as it was old and ready to be replaced it now serves a new purpose instead of being in a landfill. I just removed the cover and made a small stand attached to its base that holds the styrene directly in front of the element. Leave it there for a minute or two and presto soft moldable styrene.
--Dan
Old 02-16-2018, 10:46 AM
TDIZook's Avatar
TDIZook TDIZook is offline
Member Number: 26305
Make a wood "buck" then use a heat gun and bend around the form.
This keeps the styrene from over bending or becoming rippled.
Old 02-25-2018, 04:16 PM
I made this turbo header for my hot rod in the 1.9 section.
Used a heatgun, made the tubes longer than needed and cut to correct length when I was happy the tubes.
Tubes can not be bent as the flatten as you try to bend them.
I used a 5mm od tube and 3.2mm rod as evergreen do not carry 5mm rods.
Old 02-25-2018, 04:29 PM
Many moons ago I built this trailer.
Those wheel wells was cut 020 strips, first layer was taped to a bottle of right diameter and with overlength.
Added several layers til I had the thickness I wanted.
The glue will make it harden to the shape you just made.
For this I used plastic kit glue as that was the only glue I used at that time..
I recently used boiled water to bend a 040 sheet, that did not work for me..
Old 03-19-2018, 10:54 AM
tamiya tamiya is offline
Member Number: 1633
Styrene usually needs eating to around 150degC... water won't get there.
Old 03-19-2018, 11:10 AM
slatts1948 slatts1948 is offline
Member Number: 26482
Default Helppppppp
Hi please can you help me post something . i don't know how Thank you slatts1948
Old 03-20-2018, 09:38 AM
Spoon37's Avatar
Spoon37 Spoon37 is offline
Administrator - Professor Spoon! I have Evil Powers, and I teach! Mwuhahaha
Member Number: 16
You just did?
Old 04-04-2018, 12:22 PM
Rolex's Avatar
Rolex Rolex is offline
Young Street Urchin
Member Number: 23755
something
Always glad to help. Need anything else?
