Go Back   Scale 4x4 R/C Forums > Monsters, Scale 4X2, & Non scale R/C > Monsters of R/C
Monsters of R/C If its massive, ain't scale, and can break an ankle when it hits you, put it here!
Old 08-20-2016, 04:30 AM
Tomi_A Tomi_A is offline
Member Number: 24818
Default Mad Dog II
So, this is my current build that I started about 4-5 months ago. This time I wanted to make something old school with leaf springs and huge amount of shocks. I wanted something that wasn't so common and Mad Dog II would fit that category. I have seen only one Clod with a Blazer body.
About parts... Chassis halves are from Tamiya Bruiser and I have straightened those to suit my plans. Leafs are from Tamiya Mammoth Dump Truck. They were slightly too short so I needed to reverse rear shackles and I'll need to drill new holes in the front to get the action better. There will be 3 shocks in each corner and they are some cheap Chinese pogos from ebay. Axle cases, transfer case and gear box are 3d printed by myself and I also have designed those pieces. They are based on real and rc stuff. This will be a twin brushed motor MT just for the sake of it.
To summarize:
Body: RC4WD Blazer
Chassis: Tamiya Bruiser
Axles: 3d printed cases, axial inside
Leafs: Tamiya
Shocks: 12x Chinese cheapo
Gearbox: 3d printed case, RC4WD R3 inside
Transfer case: 3d printed, RC4WD Triton inside
Tires: Clod (will get JConcept Firestorms onc they're out)
Wheels: Pro Line Brawlers +17,5 (Also will get the Jconcept Tribute wheels)
Motors: 2x Tamiya torque tuned
ESC: Hobbywing Quicrun 860
Pile of pics
Old 08-20-2016, 05:25 PM
hairba11's Avatar
hairba11 hairba11 is offline
Rollin' in the winnie
Member Number: 4269
That's awesome! Wondering how hard it would be to have the axial pinion point straight up with a bevel gear on it and another bevel gear and shaft for top loader axles
Old 08-20-2016, 05:37 PM
hairba11's Avatar
Member Number: 4269
Or even just coming out at an angle to get the drive shaft closer to the right position
Old 08-20-2016, 09:17 PM
Bullitt's Avatar
Bullitt Bullitt is offline
Long Tall Texan
Member Number: 965
The blazer body looks great sitting on top of the clod tires. I'd like to have an old school monster truck as well someday. I would probably go the King Krunch direction if I do.
Harry
Old 08-20-2016, 09:50 PM
Looneybin Looneybin is offline
Member Number: 1188
Thats cool but why not use txt/jugg axles?
Originally Posted by dremelit View Post
Nice back-half
Old 08-21-2016, 02:11 AM
Thanks everyone!
Hmm, never really thought about that or just using a different angle with the pinion. To get them straight up I'd need to make a custom input shaft. It could be done, I'll think about it. It would definately improve the looks.
I don't really like the look of those and I think my own axles gives me more freedom with attachments. There will be wire steering...
Old 09-06-2016, 01:33 PM
I have made some progress with this build. I have now all the shocks on and made a new gearbox support. Shock towers and gearbox support are made of 1,5mm steel plate. Next I'll start fabricating all necessary parts for the wire steering. It's gonna be a bit tricky but I think it will work.
Old 09-06-2016, 05:04 PM
Chevelle's Avatar
Chevelle Chevelle is offline
Back in 5 minutes.
Member Number: 20830
WOW, what a beastie I like it, Nice work!
Old 09-07-2016, 10:09 AM
Thanks, Chevelle!
Old 09-08-2016, 10:01 PM
Dominick Shauntee's Avatar
Dominick Shauntee Dominick Shauntee is offline
Member Number: 776
Very Nice !! Just my style I considered doing something similar but moved on to another project
Old 10-14-2016, 03:02 PM
Thanks, Dominick!
I have worked with the steering this week and I'm about ready to start testing. I hope it works.
In the rear there's wire system and the front is traditional for now.
Old 10-14-2016, 09:44 PM
Member Number: 776
Thanks for update keep us posted !
Old 10-16-2016, 08:23 AM
Steering testing done and it was a success.
I will change the front to wire system also. I think wires works better in the back than the rod in the front. So rod goes to trash and in comes wires.
Old 11-04-2016, 06:03 PM
markturbo markturbo is offline
Member Number: 3889
Nice build, I like the old school look.
Old 11-09-2016, 11:35 AM
Thanks markturbo! Yeah old scholl, it's something different.
Front is now wired too.
Next, I'll begin to mount the body onto the chassis. I think the body will need some kind of support frame and chassis attachments. Perhaps tube work of some sort...
